Page 13 of 14 FirstFirst ... 3891011121314 LastLast
Results 181 to 195 of 200
  1. #181
    Mar 2012
    Shall I log back in to dc unlocker ? Then what? Where do I click ?thanks !!
  2. #182
    london
    on the dc unlocker site when you log in you will see the flash button, but it would be best if you just looked on their forum for your model. but make sure that you get the correct unbranded firmware. normally when you get the unlock code it also gives you the flash code.....
    i never use dongles if im mobile as can just use my galaxy note as wifi hotspot and use my giffgaff sim which is unlimted even for non mobile data. did 7gb file fast and did not even get a data usage message
  3. #183
    Jul 2013
    Is there anyway round the number of attempts to unlock a Huawei E5830? Bought one off ebay and it is already saying 0 attempts. locked to 3 network and want to use orange.
  4. #184
    Western Cape, South Africa (Ex-UK)
    Quote Originally Posted by ColetteC View Post
    You can try flashing but in general, you'd need to pay... Try www.dc-unlocker.com as their client software has the ability to both unlock and reset the tries counter.
  5. #185
    Jul 2013
    i have to wait 15 mins
  6. #186
    Jul 2013
    I have problems unlocking huawei e272 dongle (from vodafone UK). I can't seem to connect to it with any unlocker, firmware updater or any other kind of software like that :/
  7. #187
    You need to have installed it first, i.e. let the self-install run.
    Then with all of the software (except drivers) closed down, you can upgrade the dashboard to Mobile Partner or simply unlock it.
    Vodabloat (Vodafone software) will not allow you to use any SIM other than a Vodafone SIM even if the modem is unlocked!
  8. #188
    Jul 2013
    Quote Originally Posted by Jim.Mahoney View Post
    Thanks a lot, that helped with everything now it's unlocked and works fine with my thee sim card
  9. #189
    DK Veteran deffc0n's Avatar
    UK/POLAND
    I have medion Huawei model s4011 where find solution unlock this modem ?
    br
  10. #190
    Nov 2013
    Hi i have huawei e353s-2 hilink modem. I need to disable hilink feature and convert to ordinary dial up modem.I tried somthings to show com ports and setup dial up connection but still can not connect to internet. It gives errror probably ports are closed. So decided flash firmware to modem. I found firmwares belongs to other versions of e353. But it ask flash password.So i came here. Where can i find flash password.
    Detailed info
    ;Manufacturer :huawei -
    Model :E353 -
    Revision :22.157.39.00.170 -
    Phone IMEI :867989010512529
    i need help badly.
  11. #191
    This place offers both Unlock Codes and Flashing Codes: Huawei Unlock by IMEI but remember to request the Flash Code.
  12. #192
    Dec 2013
    Hi all I have a E1752cu
    IMEI: 352964045607620
    Could anyone help with the unlock and flash please
    Many Thanks Tony
  13. #193
    Quote Originally Posted by kudos1uk View Post
    Many Thanks Tony
    As it's Christmas:
    Unlock Code: 66451306
    Flash Code: 52548754
    If this doesn't work try here: http://huawei.site90.com/
  14. #194
    Dec 2013
    hi guys, i have a Huawei Inspira (H867G).I also believe i got the unlock code for it.... however the phone does not ask for unlock code when inserting any SIM.
    I downloaded a few variants of the modem code writer, (including mobile partner that i found on this site). However when i connect my phone to my laptop using the usb cable that came with the phone (i also tried a couple others) the software does not seem to detect my phone (my laptop detects it fine, with out any issues)..
    can some one please advice if i am doing something wrong or any next steps?
    TIA...
  15. #195
    Quote Originally Posted by indgirl6 View Post
    TIA...
    This thread is for Huawei Modems and you have a Huawei Phone... Spot the error?
    Mobile Partner does NOT run with Huawei Phones only Huawei Modems!!
    Likewise, the code writer you have tried would also be for Huawei Modems!
    If your handset is not asking for a code, then it may be unlocked already. If you don't see a network it may be set to the wrong band or the handset could also be blacklisted (you don't give it's history) so it's hard to tell.
