Hi APOLLO29 ! you tried to close the crystal oscillator? could be it! connect only the pins 1,2,3,4,5, and 8 of the eprom too!
I have done a Honda Fit 2009 93c76.
I removed the eeprom and reprogrammed it and everything is ok
I followed the circuit to the back side to read it with upa and don`t extract needles every time a have to make one, but can`t read it with upa.
Always shows the same error
Reading: 1 Errors Found Device: 93c76 Range: 0 - 3FF
CS Error.
I?m sure i followed the circuit ok
Has someobody done this dash, what am i doing wrong?
hi
no need crystal short just check the wires u connect at position 1,2,3,4,5,8 and read like 93c76X16 and u get perfect data file.After that u know what to do with this file.
Thankx
hi
you have to make it like this or need to buy that.Adaptor price is more than that of upa programmer itself.
Click on search u find reseller or contact HCIP for schematic of these adaptors.
Thankx
dashradio (30th August, 2017)
I believe that question was "what is that interface for?"
I suggest reading chips on board?? Is it right?
Intented Read 3.3 volt and read quick
hi
hcip know ic numbers.Ask her for ic number
Thankx
Sorry mate about schematic but I promise to arthur that never distributed the scrematic of this
I am very sorry about this matter, I hope you could understand
: Disparo:
HI , Can you Pm me the Honda Fit 2008 Pin out picture? i need it , because i think the spec is same with our malaysia, i still searching for honda city,accord pin out, because the needle is very hard to pull out. thank you if can share with me. really appreaciate your helping every time.
Here you go .. 6 = +(pin8)
Cesar Alfonso (7th December, 2020)
