Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Honda Fit 93c76
    DK Veteran Apolo29's Avatar
    Mar 2010
    Default Honda Fit 93c76
    I have done a Honda Fit 2009 93c76.
    I removed the eeprom and reprogrammed it and everything is ok
    I followed the circuit to the back side to read it with upa and don`t extract needles every time a have to make one, but can`t read it with upa.
    Always shows the same error
    Reading: 1 Errors Found Device: 93c76 Range: 0 - 3FF
    CS Error.
    I?m sure i followed the circuit ok
    Has someobody done this dash, what am i doing wrong?
    DK Veteran marcio1758's Avatar
    Aug 2009
    Hi APOLLO29 ! you tried to close the crystal oscillator? could be it! connect only the pins 1,2,3,4,5, and 8 of the eprom too!
    May 2011
    hi
    no need crystal short just check the wires u connect at position 1,2,3,4,5,8 and read like 93c76X16 and u get perfect data file.After that u know what to do with this file.
    Thankx
    hcip's Avatar
    Dec 2009
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    I read it with UPA without problem
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
    Mar 2010
    Quote Originally Posted by hcip View Post
    What does that interface between upa and dashboard do?
    I have original Upa, but don?t have that interface.
    May 2011
    hi
    you have to make it like this or need to buy that.Adaptor price is more than that of upa programmer itself.
    Click on search u find reseller or contact HCIP for schematic of these adaptors.
    Thankx
    hcip's Avatar
    Dec 2009
    Quote Originally Posted by digimile View Post
    hi
    Thankx
    Sorry mate about schematic but I promise to arthur that never distributed the scrematic of this
    I am very sorry about this matter, I hope you could understand
  8. The Following User Says Thank You to hcip For This Useful Post:
    dashradio (30th August, 2017)
  9. #8
    martij976's Avatar
    Jul 2010
    I believe that question was "what is that interface for?"
    I suggest reading chips on board?? Is it right?
  10. #9
    Top Poster boratokm's Avatar
    Jun 2010
    Monterrey Mexico
    Default Read 3.3 Volts
    Intented Read 3.3 volt and read quick
  11. #10
    Mar 2011
    Quote Originally Posted by boratokm View Post
    Thanks boratokm, so this is the purpose from that interface ? do you know what kind of chip/ic on that adapter ?
  12. #11
    May 2011
    hi
    hcip know ic numbers.Ask her for ic number
    Thankx
  13. #12
    Jun 2010
    Monterrey Mexico
    Default hi hi hi yes ask to HIL
    : Disparo:
  14. #13
    Jul 2010
    HI , Can you Pm me the Honda Fit 2008 Pin out picture? i need it , because i think the spec is same with our malaysia, i still searching for honda city,accord pin out, because the needle is very hard to pull out. thank you if can share with me. really appreaciate your helping every time.
  15. #14
    Feb 2010
    Here you go .. 6 = +(pin8)
  16. The Following User Says Thank You to nomis For This Useful Post:
    Cesar Alfonso (7th December, 2020)
  17. #15
    Jul 2010
    Smile
    Quote Originally Posted by nomis View Post
    Thank you so much nomis, mate. Do you have honda accord and honda city pin out ? very appreciate for your sharing... tQ
