Hello.
Are you using wired or wireless ?
Regardless of what you are what i would check first is your IP address to see if you have one.
There are two ways to do this either graphically by going to the Up and Down Arrows by the clock, left click on it and go connection information and it should give you all your important IP information.
Or by command prompt which in Ubuntu is called Terminal which you get to by going to Applications then Accessories then Terminal. Once in Terminal type ifconfig this is the equivalent to ipconfig in windows.
While in the terminal type ping www.bbc.co.uk and see if you get a reply. Ctrl + C will stop the command otherwise it will go on forever.
Depending on whether you have an IP address or not controls what the next thing to do is.
