please, i need to activate V8.10 :
R13A2-K84H6-6E413-400F5-P5285
thanks for any help !!
hi friend's i have a one EXAMINER original tool.i instal it the 8.20 version but i need code for progressing.
i need code for this:X03W6-J47M3-9W414-410Z5-F94C8
i wait for any help.
regard's to all
I work with Examiner Smart V7.60. I would like to perform update V8.20. Can anyone help calculate key?Please write me PM. I will respect your prize
Thank you very much
i never tried a Fiat 500 but i guess it will work with the latest full version...
Actia Italia has stoped technical support of the old fiat examiner since the new one called Wi-tech has taken place.
Checking Touch panel LCD
Try start examiner with RECOVERY CD to adjust the Monitor
and see if it really works ( Win98 first edition )
Thats the bad thing no drivers easily found.
Fiat 500.
If KM blink there are 3 possible solutions.
1) PROXI alignment
2). Re flash There was a flash to solve this problem
3). Blue&me Microsoft or Laubehorn causes that sometimes
when you remove the battery plug, so you need to stop engine
remove BAT (+) wait 5 minutes replace plug and wait a bit
to turn key ON.
All above have happened to me in many case so far.
[QUOTE=gmakris;182842
Fiat 500.
1) PROXI alignment
to turn key ON.
All above have happened to me in many case so far.[/QUOTE]
new dataset was loaded into instrument cluster, thats what caused it.
Can fiat ecuscan solve this problem?
please, i need to activate V8.20 :
i wait for any help thanks for any help !!
REGARDS
please i need to complete the code for my examiner, here is the info:
TIPO_CD=EXAMINER
REL=6.40
PROGR=1.0
and the code that i need to complete is:
P 0 ? W ? G ? ? J ? 1 X 5 1 1 3 5 0 U 4 Q 9 2 1 6
thanks!!
please help me if you can , i wish to activate a software cd 7.20 examiner
thank you .
Hi!
I have examiner plus, hdd died.
I installed again, but ask for a new code.
Release:7.80
code: O26I8-F35L7-5U418-390S4-S514B
Please help!
Thank you for the help in advance!
PROBLEM SOLVED.
Hi guys, i have an examiner that i repaired the touch screen on and after calibrating and reinstalling the software it now need activating, can anyone help me please as i have customers waiting for diagnostics...
J04W2-B71I5-9E414-410T5-P0D61
