Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Port Elizabeth
    Default Golf 5 gti immo light!!!
    Hi I have golf gti med 9.1 and would like to know how to turn off the immo active warning light as this vechile had the immo removed so just want flashing light off and the immo active in central display
    Shane
    Prussia
    Quote Originally Posted by shanektm450 View Post
    Shane
    think its not possible
    yes, possible with learning key
    mastaflex's Avatar
    Jan 2009
    FR47310
    remove immo LED
    remove led will not remove message from display
    Port Elizabeth
    Quote Originally Posted by exe123 View Post
    I can make a plan with the led ,I will connect it to the airbag light so it goes out but the display is the major problem ,I must be able to edit the cluster dump to erase that part of the information or change it to diffrent message like "PURE POWER" what do you guys think of that ??????????????????
    Port Elizabeth
    PLEASE ANY HELP WITH SOLUTION!!!!!!!!
    Like exe123 say before. Program just transponder to dash! It is best way. From what Year is dash?
    PS
    Or when You will You can paint FIS with black color and message will be not more visible..
    learning key is just possible with adapted ecu. so in this case not possible. if dash is after 2006 he can add key with tango via dump + mcu content without learning. but I doubt that he has tango.
    if you put the dash with adapted ecu you can put immo off and the dash dont show the immo error but you need adapte the ecu whith the dash you need the old login code and you need put in the new dash , is this dash a new on or is a original dash???
    Top Poster automan123's Avatar
    Mar 2011
    Yeah that gonna ......msg string should be somewhere at eep or mcu.
    Prussia
    thats why I said not possible!
    Everything is possible with knowledge and equipment, but in that case I thought "not possible"
  13. #13
    Port Elizabeth
    I have most programmers plus zedbull "GENIUNE" but cant do it 2005 model gti cluster ecu and rest from donner cars, I need you guys to help gos it is a problem in S.A I caN help with something els just ask ,
    PS! I can fix anything except woman ,once they go faulty get new one.LOL!!!!!!!!!!!!!!!!!!!!!!!!!!
  14. #14
    U.S.A
    read eeprom dump and flash mcu...post both here...maybe i can do it something for you....what year is dash?
  15. #15
    Port Elizabeth
    Quote Originally Posted by maumaumau View Post
    Dash 2005 will post dump later cheers !!!!
    Shane
