Results 1 to 7 of 7
    Nov 2009
    Default DVD PCB Board Replacement
    Hi all, I have bought a faulty wii that won't read discs, on opening it up i have noticed that someone has snapped the plastic bit off where the dvd drive ribbon slots in from the console so therefore i believe this is the reason it will not work.
    The pcb board is GC2-D1 can i just replace this board and if so do i need the same one , ie GC2-D1 or can i use a D3-2
    Thankyou.
    V.I.P. Member ck-ok's Avatar
    Dec 2008
    nottingham
    Quote Originally Posted by DAVE466 View Post
    Thankyou.
    if all you want to do is repair it and play originals then any board will do, but if you want to mod it and play backups then dont get a D3-2 or d4 drive as these cant play backups.
    Nov 2009
    Thankyou for quick reply.
    It will be used to play originals and also for the use of usb loader.
    Will game discs still install to hard drive through usb loader using different pcb?
    Dec 2008
    nottingham
    yes you can still backup your originals to usb with any pcb.
    Nov 2009
    Thankyou very much mate. I just assume its just a straight swap over with the little bit of solder?
    Dec 2008
    nottingham
    yeah this will give you an idea Guide: How to Install / Replace / Change your Wii DVD Drive PCB WiiDriveKey.co.uk
    Nov 2009
    Yeah already taken it out mate but thanks for the advice really appreciate it.
    Dave
