Results 1 to 12 of 12
    Feb 2010
    Default Subaru 2008 Mechanical Key code
    Hello,
    Can anyone help me with a JDM 2008 Subaru Impreza Mechanical Key code with chassis code GH8-004780.
    Regards
    Feb 2010
    Did this job today in 20 minutes.
    T series Code was easily be found on the Driver door lock by simple loosening the screew ( same as on the newer Toyota's ) and pulling the lock about 1/2 out of the door and you find the code on the TOP of the housing.
    Cut by code using my Subaru depth space keys and program with T300, done in 20 minutes.
    gokey's Avatar
    Feb 2010
    for programming new key , need login code ?
    Feb 2010
    Quote Originally Posted by gokey View Post
    No, no login code neded.
    T300 did not ask for one, this was a all keys lost job. SBB clone should also do this job because Subaru really have not change their key secuirty program since 2000
    all the way up to 2009 when they went to Can and smart Keys.
    gokey's Avatar
    Feb 2010
    I have a similar work
    IMPREZA 2007 all lost keys
    fail to stop the alarm to program new key
    what transponder did you use? id62 ?
    Feb 2010
    leganza 2007 all lost keys
    Yes ID 62
    BUT I always thought leganza is a Daewoo
    Daewoo Leganza - Wikipedia, the free encyclopedia
    gokey's Avatar
    Feb 2010
    UH
    my mistake
    car is IMPREZA 2007 !!
    Feb 2010
    I did a Google search today on how to program the remote and most people were saying to CUT the wire to the Alarm Horn to avoid the noise and continue as usual with the Remote programming so I would try the same to program the key.
    When key programming is done you re-join the wire to the Alarm Horn.
    Do a seach with google on "how to program 2007 Subaru Impreza Remote" and you might find some help
    Regards
    Hanukkah's Avatar
    Feb 2010
    Hi shitad... Will T300 work on a 2011 Subaru Forester also? Thanks...
    Feb 2010
    Quote Originally Posted by Hanukkah View Post
    I dout this since AD had to write new software for 2011 up Subaru.
    The truth is I have not done a 2011 so I am not 100% sure but I do have my douts that T300 can do it. There is no arm trying however because most Subaru up to 2010 is on a tpye 1 system if it is not a button start
    Regards
  11. #11
    Hanukkah's Avatar
    Feb 2010
    Quote Originally Posted by shitad View Post
    Regards
    Did try doing this via immo dump... but was not successful. Maybe something different in 2011 models...
  12. #12
    Facelift models are with 4d62 80bit chips.
