Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Hybrid View
    Feb 2010
    Default UR v9 Image CCcam isssue on TGM220
    Hi Guys
    I've just installed UR v9 image on my TGM220(with SAT Tuner installed)
    I can't seem to find and download CCcam 2.14. I've tried the blue panel and there is nothing. I've also tried to do it manually by ftp'ing a CCcam TAR file to the temp directory and installing it. but I do not get the CCcam option in the softcam selection box.
    Someone told me to ftp the 'Extra URL' file to the VAR/ETC directory, but this did not work either.
    Any ideas anyone?
    Thanks in advance.
    plasterer's Avatar
    Jun 2008
    Mersyside
    Try going backto V8
    And axess the panel then ..............Paul
    PAUL
    Aug 2008
    Wild Mild West
    Press blue button then press blue panle button, scroll to add on manager,and your ccam 2.14 should be there, press green to install.
    or
    or instead of the green button press manual yellow button and in the drop down menu on the next page it should be there and install.
    i cant quite remember which way it is for a manual install but its one of the two ways above.
    ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
    Feb 2010
    Quote Originally Posted by andiewill View Post
    or
    When I go to addon manager, it is blank. There is no CCcam 2.14 listed.
    plasterer's Avatar
    Jun 2008
    Mersyside
    Havent tried V9uk
    But V8 in this post will acsess panel ..........Paul
    http://www.digital-kaos.co.uk/forums...-image-149695/
    PAUL
    Aug 2008
    Wild Mild West
    Just tried v9 for a mate who is updating and had no joy with that image ftp -ing or internet download ?, but as stated v8 works ok, i could never get the update for control panle to access Cccam 2.14 to work, but a manual install works fine unlike v9 which is a shame as everything i tried did not work except itgate edit, but when i get a bit more time i will have a less haste go at it again.
    Member shamusbhoy's Avatar
    Nov 2008
    V9 working ok with me, panel downloading cams,channel lists
    etc but can't get a backup.Tried Conrol Centre 2.5, goes through the motions, reboots box then nothing so I must be doing something wrong.Wait and see if freck has any joy.
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    I'm in the same boat as you now shamus,heres my story
    1.Booted box holding ^ button on receiver and done a factory reset just to flush the var and start fresh.
    2.Flashed on V8 Ireland Edition(makes no difference on sat) with no probs.
    3.Ftp'd to box and put Andiewills CCcam files into tmp
    4.Went back to box and hit blue button twice and scrolled down to addon manager.Youll then see your CCcam files and hit ok to install...cam will then show in smatrcam menu(blue button once.)
    The full install also creates the CCcam.cfg in var/etc for your own use.Also put in latest Sly channels with DB Edit.
    So job done....then the shit hits the fan trying to backup the lot.
    Flashed box with Control centre 2.5 so i stuck with that for backup.
    In Flash Backup I chose ALL .ie Var and Update in one,box goes tru the motions and you can see you var files plus bouquets backing up....then comes the dreaded ####dump start ok message.
    Waited a while and nothing happening so left it....still nothing and while im typing this...still F.A.
    Tried every variation of backk ups and only managed to get a poxy channel list from the whole back up option.
    We're obviously overlooking something here but I thought I'd copy out my whole var folder and post it here along with the V8 image and control centre.A complete image can then be compiled just by overwriting the var folder on V8 with my one complete eith Cccam2.1.4 and update channel list and bouqets.
    Its var.tar.gz and you can try it with the backup function on the control centre.
    Got everything I needed up and running and happy with it,thanks to Andiewill for support and Plasterer always behind me....cheers lads
    Thats all for now,might have a go off the EDG NEmesis laterz.
    May 2008
    Quote Originally Posted by shamusbhoy View Post
    shamusbhoy have you tried the enigma web interface? i managed to bk my v9 up,when in there press config then flash manager,i,m sure you can work the rest out.
    Nov 2008
    Yeh see what your saying m8, I did the same in 7.9 had to ftp cccam on manually, but when I put V9 on the panel gave me all the downloads eg cams,channel lists,skins, addons etc so didnt have to ftp anything. Did exactly the same as you in ICC 2.5 with the same results so beginning to sound like a bug or we're missing something.
  11. #11
    Jul 2008
    Yep sound like it alright....so V9 is the image for Itgate Sat.
    Problem solved for all other users.
    Freck
  12. #12
    plasterer's Avatar
    Jun 2008
    Mersyside
    Is there a link for v9 posted
    or can somebodyup the image ,Thanx ..........Paul
    PAUL
  13. #13
    Feb 2010
    Hi Guys
    I've got v8 working after installing CCcam manually.
    But i'm in the same boat when it comes to backing up the working image, just haven't been able to do it.
  14. #14
    Jul 2008
    Quote Originally Posted by plasterer View Post
    V9 now up Paul
    Freck
  15. #15
    plasterer's Avatar
    Jun 2008
    Mersyside
    yer just put it on a 200
    Blue panel acsess no probs
    Thanx chaps
    EDG on a 220 no panel acsess on that one 4.4 i think it was...Paul
    PAUL
