Results 1 to 8 of 8
    Jul 2011
    wrexham uk
    Default volvo c30 d5 prog key
    Hi can anyone help me with this one, i need to reprogram a key for the above vehicle. I have the original and purchased a spare on fleebay. is it possible that this could be cloned. this my own car and V5 is in my name.
    Volvo want ?140-200 for a new key. Any Help would be appreciated. I have an Autoboss and autel diagnostic tool but havnt used it for keys before.
    key-maker's Avatar
    no one can check your dealer is the best way for above 2003 no one can best wishes
    Jan 2011
    Romania
    Only new keys and remotes can be programmed .
    U cannot clone the code hopping encoder, it can only be read once after programming .
    Czech Rep
    Hi all,
    I have got one question. Can You help me with this?
    I have got one Volvo key. Transponder working on this car, but I need reprogramming remote control to this vehicle. Is possible do this? This remote control was programming on this car before wash on washmasine. I have this repaired. And now I need this programming.
    Many thanks for any ideas.
    Martin
    DK Veteran gtmech's Avatar
    Hell
    Quote Originally Posted by simon4859 View Post
    cloning a late model Volvo key? Your definitely new to the key business arent you mate? Rule number 1: Volvo keys = absolute nightmare for all of us, nice car though
    Czech Rep
    gtmech: I need only learn remote control to this car. I have got good transponder which is working on this car.
    Many thanks for help.
    Hell
    Quote Originally Posted by matias View Post
    what kind of Volvo is it? year? model?
    Are you sure the key has been repaired properly? Volvo remotes and keys are programmed through diagnostics so even after repair should not need re-programming again, sometimes (usually if system has crashed) its needed to do again but you need volvo diagnostics to do it, you sure remote key is transmitting properly? Water is a killer so you want to be sure that its been repaired properly.
    Czech Rep
    I can maby repair this key. So I think if I buy used key, change transponder from old key. To new (used) and need reprograming remote. Is it C30 2009 1.8 and on the box of the key is MIX 1400022. What is this number? Any login?
    Thx
