Results 1 to 5 of 5
    Sep 2010
    Default I need Fap removed Peugeot 607 2.7 HDI V6 04 year
    I have a problem with the 607 2.7 HDI V6 04 year.
    Ecu SID201 5WS40060I-T
    All dump ecu by cmd in atach.
    Ecusafe did not work. Any suggestions? thx advance
    Eight's Avatar
    Bosnia and Herzegovina
    Try this dump and report. Pass on PM. Hope that your tool calculates checksum!
    BR
    Sep 2010
    Your modification is no different of ECU Safe and not work
    After about 2km by car ecu error message ..differential
    pressure sensor fault or fap filter missing......
    PSA while driving shows 0 mbar pressure difference ? ?
    any suggestions
    Emulator !
    Ecu shouldn't see dpf sensor if it will be removed ok from software...
    Use emulator. It's problematic topic with these psa dpf's.
