Results 1 to 7 of 7
Thread: windows problem
Hybrid View
    V.I.P. Member andy4's Avatar
    Apr 2008
    little wigan
    Default windows problem
    when i click on icons to open windows screen only small
    i know i can click to make them bigger but does anybody know
    if there is is some where in pc that i can alter so they open
    large all the time thanks
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    right click on your desktop. the display properties window wil appear, click on the appearnace tab, then click on the 'effects' button. In there you will see a box for 'large icons' tick it, click on OK, then apply and ok . the window should close and your icons should now be big..
    Apr 2008
    little wigan
    cheers for that nige but it's not icons that need it
    it's when i click on on icons i need windows maximizing
    Feb 2008
    In my Cave
    so what you are asking is when you click on an icon and the program opens up in a window, how do you get the window to open full screen everytime?
    Apr 2008
    little wigan
    you've got it, the screen is only small i know i can click on screen to max it
    but want screen full ever time
    dasteph's Avatar
    Nov 2008
    north east
    when the window opens put your screen cursor at one of the bottom corners of the window and drag the box diagonally it should stay at that size thr next time you open that particular window just do the same for any window that is not big enough.
    Member ferretuk's Avatar
    Nov 2008
    windows 7 does that tap in the window it maximizes other os dont do it by default and ive not look for that option just install windows 7 and thought it was cool
