i have this ecu (second pcb from marelli MJD for 1.3cdti corsa D)
in BDM info pdf probable the pin1 is wrong.
Any tested diagram ?
thnx
marelli_1.3_MJD_MPC563
thnx
Well after some more searching I found this PDF which came with this BDM I bought a while back: https://rapidshare.com/files/4419021...rog_PE_ENG.pdf
I'm not using this BDM for the job because I don't seam to have the algorithamAnyone have one ?
I have a clone BDM100 & clone X-ProgM.
I have opted for Xprog on this, ground pins have been identified I have tried a selection of pin out options (powering ecu up stand alone) but Xprog shows the screen attached it just sits there which is sort of a result, better than the silence treatment
Any help or suggestions would be great.
The car aparently runs with this ecu so I don't think this is the problem..
Darwins
NOW SORTED
Go for it. The future is promised to no one
Hi guys I do not use x prog m bdm
but I see that the connections are wrong
I made a pattern for me
if someone wants to try it
Download magnet10.jpg from Sendspace.com - send big files the easy way
http://www.sendspace.com/filegroup/4...Uia9u1JcQWYIhQ
http://www.sendspace.com/filegroup/G...SLuEJRlKbkjKVg
tested 100% no need adapter 9s12 for this...
448kb dump are ok 100% are full without eeprom i chek also chksum with winols ricognize ok 100%
for read eeprom select mpc eeprom and read also
x prog m can read write this without problem
only the best
eprom!
regards
professional chiptuning and electronic car repair...four-DynoRace_ wheel_ dynamometer
Min2xx (4th September, 2013)
I see that many here talk talk but did not understand anything
I had 5 minutes and I thought to try
to raise doubts
regards
i have read all post for this thread,
but all talk for 2Mb dump from this ecu series.
need make off DPF & just i read experts from here for
some info about that.
friend yas200979 say can do that but need full dump (with BDM) from ecu.
always the first time is difficult,,second time it's easy & cheap :-)
thnx for yours ,time help & info
HELLO ALL
please i am sershing how can i read this SIMENS ECU flash by x prog
MPC561MZP56
AM29BDD160GB
REGARDS
some help with the scheme bdm pinout
bmw x5 edc16
Hi to all
Whoo have a clear picture with a edc16 cp from vw crafter,i need full pbc picture if sombode have,from mi missing 3 pices and i dont know wath missing,so if ombode have a picture please share.
I let down the number of ecu
bosch 0 281 013 700 edc 16cp
vw number 074 90 032 ag
thank u
If u have the answer say Thank You!!
Hi!
I have 1 EDC16cp34 ecu , 074 906 032 AT , 0 281 014 133 .If you need thursday I can send picture.
Br
Hi!
I hope help for you.
https://rapidshare.com/files/3859929071/Crafter.rar
Br.
Very halpfull your pictures,thank you!
can somebody help me for pinconnections on this ecu
for bdm100 chinese.
please
Hi!
This is standard bosch BDM ports
Hello everyone
I need help on XPROG-m BDM adapter
my adapter is not reading,
I went to check what had happened,
gave a component of adapter, from what I saw in some photos is a capacitor, does anyone know the value?
