Hi!
"bdm2.jpg" is standard bosch bdm port
Use this .
Hi!
Use this .
delphi ecu
pls send me pin out for xprog how to read thnks
capi (8th May, 2013)
Hi!
I read the whole thread and not realize that I should always use the BDM adapter or not?
Regards.
I answer to my question: "always look connecting diagram!"
hi frends i hav to clone edc16c9 ecu from opel astra h the car crash in front and old ecu is smashed i hardli opened the ecu.
I hav second hand ecu wih same numbers wot i hav to read from old ecu and program in new can i program with XPROG-M
i read info wit xprog can some one check please
Friends. I need to know if possible reading by BDM, this ecu Hyundai Sonata N20 in 2006. Please if you can help with connections to the reading. I have tools and XPROG BDM100 Thanks for your help
bmwhunter (29th March, 2013)
Interesting ecu! EVC's BMD100 schould be able to do that.
Look at page 29 of the following docuement: http://www.evc.de/ftp/winols/BDM100en.pdf
Best wishes
Thanks friend for your help, I bought the tool which is attached hereto. can someone please help me with how to do this reading to the ECU Hyundai Sonata N20?
if anyone can compratir a video on using the BDM or any material that helps with this reading, I'll be very grateful
Hello everyone
Yesterday I try to clone an engine ECU BOSCH EDC16c3, for the memory Flasch by galeto no problem, also for the eprom with a programateur external impeccable, the problem is the MPC555 I use the BDM connections as shown in the topic, reading chip is ok, programming chip is ok, but ECU is not good, by galeto impossible to read this ECU (ECU not recognized).
It would be nice of you to help me solve my problem
is it possible to read and write MPC 555 by XPROG-M (BDM connection) or not
See post #181.
i do exactly a same work but without success !!!
i use xprog-m V5, something is wrong !!
somme help
Check this one, ground to the body. Tested many times.
thanks nanux, i try in first by this schema (i now it is yours in poste 94), all is ok but ECU In car don't work !!, may be it is about file size 448 Ko and 452 Ko ??? no ??
