PSG16 Final Pinout (Bare DIE engineering by BIZTeam).jpghelp psg16 connections xprog m thanks
Hello. I need one way to read and write With Xprog flash ST10F269 is one Visteon DPC-806 Ford Transit 2.0TDDI is one way to this plug but i don.t know how .Thanks Visteon.JPG
Hi,Bali Motor.
I need help.
I have a problem with ecu me9.7 mercedes, number of MB A2721531679 / 0261209040.
The original ECU burned, with reversed battery,
not reading this with bdm, XPROG, etc. , to no avail.
I found a short in the 5 Volt feed in ic 95080, but have not found where.
I ask:
if I get put in another used ECU equal and good, the 95080 and flash m58bw016db80t3f ,
the car would work ?
or maybe also needs replacing the processor mpc564?
Thanks in advance.
Hi about clone ecu - if your second ecu is the same HW/SW number just you need to change eeeprom and flash (replace) from the burned ecu to the new one if they are not burned , (you can try to read them with programmer ) .
And the car will start .
Regards .
This thread is very interesting and helpful - nice .
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
HI,oversOull
yes, the second ecu is the same HW/SW number,ecu me9.7 mercedes, number of MB A2721531679 / 0261209040.
i will change , the eeprom 95080 and flash m58bw016db80t3f ,
i will trye.
i ask:
second option:
how can I renew ecu used for replacement ?
thank you.
hi.
I can read in direct mpc564 ic, which pins will make the connection, someone did this reading.
thanks.
I need bdm connection for this ecu daf xf
can't see p/n on ecu but it looks like Delphi ecu
br
I need connection of 2J74Y Mcu for rear Sam Mercedes Benz
hi i need the connection from this micro mpc564mzp56, the ecu is from ford f150 fx4 2009
hi, this thread is very usefull, interesting and helpfull. keep it up boys thnks for all who contributed
hello you managed to read this ecu visteon st10f269?I have the same problem,can you help me with a pinout for xprog-galletto v53-54?
Need bdm connection for edc7 man tga ecu
Hi can someone give me connection diagram for audi a6 2005 steering lock module if need be i can post picture later
