I have problem reading HC(s)12 EPROM and flash, error xprog can not recognize BDM adapter, and asking to install adapter, xprog v 5.51
Last edited by Johnner; 25th July, 2015 at 12:12 AM. Reason: No references to other forum staff members please
Hi Guys
Excellent thread.....
Is the problem me or has something changed on this thread because I cannot view the diagrams. I am looking to do a BDM clone from an AUDI Q7 which has a EDC16 ecu.
Original ECU water damaged. So got new ECU. Can I use Xprog to clone over old data?
Diagram for Xprog to BDM would be much appreciate for this EDC16.
this is normal edc16 bro , just look here and you will find it exactly for the xprog , and yes if you can connect tot the ecu , and read it on the bdm hole ecu , just you can make the swap of the ecus . Just write in the google xprog edc16 bdm and you will find it from the first 5 picsand here is the connections .
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
Does the ECU need to be powered up?
I gave it 12V on those pads as per diagram above but still not reading. Xprog just says initialising device and does nothing else.
dear mr overs0ull
i try like u sher her but wihtout sacces x prog say device is silent alsow with extrnal power sem resulte eny more info pleasr
regards
A lot of pictures are missing...anyone have connection for Simos 6.2?
CONNECTION PLZ
MPC555LFMZP40
INTEL DE28F800
أرسلت من LG-D690 بإستخدام تاباتلك
kops (18th January, 2016)
USE BDM100 TO READ IT
what about finally with marrelli ecus and xprogm read and write?good or not?safe or kill ecu?
and where are all the fotos from grinovsky member?
Ive got sprinter ecu delphi
CRD2.30 OM651
MCP5566
is xprog m 5.5 able to read and write ok? Via BDM or other ...?? If so can some one share pinout please??
Thanks in advance.
Nope xprog can tread write
thayer201 (20th March, 2016)
This is done over jtag! Xprog cannot do it.
ok thank you
