Why you have those pictures??? I need the peugeot, renault, citroen, opel and wv pinout..
Thankyou lfor your help
I wish to want dcu102 or visteon pinout for xprog...
Hi, is that You need?
yes thankyou your help..
i want to know:
you where know this pinout ???
hankyou
Using multimeter, You will found that is OK.
Hi grinovsky!
This is 2 file,if you need I have file from bmw ecu(N42B20 with ME 9.2)
Best regards
thanks for all mate for this good info of bdm pin
nice
so,you sayed that you had read mpc556 from used ecu and write it in a seconde hand ecu and it was succes!!
ok,can you find answer of this question:
your mpc556 dump have 448Ko
so,you had read flash : 00000 to 6FFFF
BUT,this is wrong,becose if you read the same mpc556 with BDM100 you will get 452Ko
becose you will read flash :00000 to 70FFF
SO,you don't clone the right flash in mpc556 with xprogm
becose you don't read/write flash :70000 to 70FFF
how it can be succes?
Just one quote from MPC555/6 datasheet
448 Kbytes of CDR MoneT Flash EEPROM Memory (CMF)
***8226; One 256-Kbyte and one 192-Kbyte module
***8226; Page read mode
***8226; Block (32-Kbyte) erasable
***8226; External 4.75-V to 5.25-V program and erase power supply
other question
this is a dump from ford focus ecu(delphi) read by BDM100 and have a size of 452Ko
i send it to EVC to compare with original and this is there answer
can you have the same answer from EVC with 448Ko dump
t1tan1 (1st April, 2014)
BDM read MPC flash with configurations, thats why its dump bigest then X-Prog. I have good experiance reading\writing MPC 555\556 with X-Prog.
Renault Megane Ecu(edc16c3..) mpc 556 replace today.
@ kareszka
is your whole setup ACHI china of just the pre heater
u get from ebay can you link i have see a simmiler machine i am deciding on
Thanks for great work
Do what you can with what you have .
Can somebody draw connection to Siemens SID206
hi
Can evryone give me picture of renault dim1.2 for xprog
Thankyou This is bga:S
