VAG SIMOS PPD1.X X-ProgM connection
angelx431 (26th November, 2013), capi (19th March, 2015), Cesarec (23rd May, 2017), eleeinidis (27th May, 2015), IwanNIS (7th April, 2013), KennySmit (14th June, 2014), parkoto (24th October, 2015), PETERALC506 (5th July, 2015), t1tan1 (1st April, 2014), taxo1965 (22nd July, 2015), xseva (16th February, 2019)
3abas27
Just tested for you. EDC16U1
By this diagram reading no problem.
No need other connections.
Did yesterday CR3.13 Mercedes ECU as well same diagram.
I'm using original.
Maybe something is wrong with your clone Xprog then.
I'm using power supply from external HDD 12V-2A
You have to join together ground from x prog and ground from your power suplpy.
P.S I'm doing like this.
I'd say if you make connections right and can't read couple same make, similar ecus like bosh edc16
then problem is with your adapter - xprog.
I presume you are using BDM adapter same as reading 9s12?
eprommazza,
I tried before like this without adapter and didn't work for me.
So after always use it.
I have BDM100 clone, never managed to get going....always to lazy or not enough time. Or never REALY needed.
Have Kess2, for chip tuning still enough. Xprog for other works.
For edc16 connected only what is on diagram
