Page 13 of 27 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 401
  1. #181
    Sep 2009
    Hungary, Mosonmagyar?v
    Hi!
    "bdm2.jpg" is standard bosch bdm port
    Use this .
  2. The Following 3 Users Say Thank You to kareszka For This Useful Post:
    DOUGLASDL (21st December, 2015), ista74 (19th August, 2015), t1tan1 (1st April, 2014)
  3. #182
    DK Veteran technobox's Avatar
    Apr 2010
    cyprus
    Default i need to pin mb 220cdi 2007
    delphi ecu
    pls send me pin out for xprog how to read thnks
  4. #183
    Jul 2009
    Germany
    Quote Originally Posted by technobox View Post
    delphi ecu
    Hi Delphi Ecu pin out
  5. The Following User Says Thank You to 16eddi67 For This Useful Post:
    capi (8th May, 2013)
  6. #184
    Jun 2010
    Hi!
    I read the whole thread and not realize that I should always use the BDM adapter or not?
    Regards.
  7. #185
    Jun 2010
    I answer to my question: "always look connecting diagram!"
  8. #186
    stefaudio's Avatar
    Nov 2009
    BULGARIA
    hi frends i hav to clone edc16c9 ecu from opel astra h the car crash in front and old ecu is smashed i hardli opened the ecu.
    I hav second hand ecu wih same numbers wot i hav to read from old ecu and program in new can i program with XPROG-M
    i read info wit xprog can some one check please
  9. The Following 2 Users Say Thank You to stefaudio For This Useful Post:
    capi (8th May, 2013), n599fbm (16th May, 2015)
  10. #187
    achaccha's Avatar
    Nov 2010
    Default HYUNDAI SONATA N20 BDM
    Friends. I need to know if possible reading by BDM, this ecu Hyundai Sonata N20 in 2006. Please if you can help with connections to the reading. I have tools and XPROG BDM100 Thanks for your help
  11. The Following User Says Thank You to achaccha For This Useful Post:
    bmwhunter (29th March, 2013)
  12. #188
    Dec 2009
    Interesting ecu! EVC's BMD100 schould be able to do that.
    Look at page 29 of the following docuement: http://www.evc.de/ftp/winols/BDM100en.pdf
    Best wishes
  13. #189
    achaccha's Avatar
    Nov 2010
    Thanks friend for your help, I bought the tool which is attached hereto. can someone please help me with how to do this reading to the ECU Hyundai Sonata N20?
    if anyone can compratir a video on using the BDM or any material that helps with this reading, I'll be very grateful
  14. #190
    Jun 2009
    Hello everyone
    Yesterday I try to clone an engine ECU BOSCH EDC16c3, for the memory Flasch by galeto no problem, also for the eprom with a programateur external impeccable, the problem is the MPC555 I use the BDM connections as shown in the topic, reading chip is ok, programming chip is ok, but ECU is not good, by galeto impossible to read this ECU (ECU not recognized).
    It would be nice of you to help me solve my problem
  15. #191
    Jun 2009
    is it possible to read and write MPC 555 by XPROG-M (BDM connection) or not
  16. #192
    Sep 2009
    See post #181.
  17. #193
    Jun 2009
    i do exactly a same work but without success !!!
    i use xprog-m V5, something is wrong !!
    somme help
  18. #194
    Top Poster nanux's Avatar
    May 2010
    Ireland
    Check this one, ground to the body. Tested many times.
  19. #195
    Jun 2009
    thanks nanux, i try in first by this schema (i now it is yours in poste 94), all is ok but ECU In car don't work !!, may be it is about file size 448 Ko and 452 Ko ??? no ??
