Page 25 of 27 FirstFirst ... 152021222324252627 LastLast
Results 361 to 375 of 401
  1. #361
    hamzadaw2000's Avatar
    Aug 2013
    I have problem reading HC(s)12 EPROM and flash, error xprog can not recognize BDM adapter, and asking to install adapter, xprog v 5.51
    Last edited by Johnner; 25th July, 2015 at 12:12 AM. Reason: No references to other forum staff members please
  2. #362
    May 2013
    Hi Guys
    Excellent thread.....
    Is the problem me or has something changed on this thread because I cannot view the diagrams. I am looking to do a BDM clone from an AUDI Q7 which has a EDC16 ecu.
    Original ECU water damaged. So got new ECU. Can I use Xprog to clone over old data?
    Diagram for Xprog to BDM would be much appreciate for this EDC16.
  3. #363
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    this is normal edc16 bro , just look here and you will find it exactly for the xprog , and yes if you can connect tot the ecu , and read it on the bdm hole ecu , just you can make the swap of the ecus . Just write in the google xprog edc16 bdm and you will find it from the first 5 pics and here is the connections .
    Regards
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  4. #364
    May 2013
    Does the ECU need to be powered up?
    I gave it 12V on those pads as per diagram above but still not reading. Xprog just says initialising device and does nothing else.
  5. #365
    Sep 2010
    dear mr overs0ull
    i try like u sher her but wihtout sacces x prog say device is silent alsow with extrnal power sem resulte eny more info pleasr
    regards
  6. #366
    rrador's Avatar
    Feb 2011
    Tamo daleko
    A lot of pictures are missing...anyone have connection for Simos 6.2?
  7. #367
    Member kops's Avatar
    Feb 2010
    CONNECTION PLZ
    MPC555LFMZP40
    INTEL DE28F800
    Regards
  8. #368
    Nov 2015
    أرسلت من LG-D690 بإستخدام تاباتلك
  9. The Following 2 Users Say Thank You to iyass For This Useful Post:
    datapage (20th March, 2016), kops (18th January, 2016)
  10. #369
    Nov 2015
  11. The Following User Says Thank You to iyass For This Useful Post:
  12. #370
    Dec 2015
    USE BDM100 TO READ IT
  13. The Following User Says Thank You to BOSCH1 For This Useful Post:
  14. #371
    Jun 2010
    what about finally with marrelli ecus and xprogm read and write?good or not?safe or kill ecu?
    and where are all the fotos from grinovsky member?
  15. #372
    Aug 2013
    uk
    Ive got sprinter ecu delphi
    CRD2.30 OM651
    MCP5566
    is xprog m 5.5 able to read and write ok? Via BDM or other ...?? If so can some one share pinout please??
    Thanks in advance.
  16. #373
    Dec 2009
    Lithuania
    Nope xprog can tread write
  17. The Following User Says Thank You to lagas For This Useful Post:
    thayer201 (20th March, 2016)
  18. #374
    Jul 2015
    Default BDM CONNECTIONS FOR XPROGM
    This is done over jtag! Xprog cannot do it.
  19. The Following User Says Thank You to gentiabazi For This Useful Post:
  20. #375
    Aug 2013
    uk
    ok thank you
