Results 1 to 15 of 20
Hybrid View
    Top Poster Dylan Chin's Avatar
    Aug 2010
    Default Help!! Ford Ranger dashboard
    Hi every DK mate,who can advise me how i change this ford ranger 2004 year odometer.
    thanks in advance
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    Talking
    DIGA consult manual without opening dash
  3. The Following User Says Thank You to cokolo For This Useful Post:
    kasamiko (26th June, 2014)
    Jan 2011
    You could also use upa...
  5. The Following User Says Thank You to iqcaraudio For This Useful Post:
  6. #4
    Mar 2014
    Philippines
    Quote Originally Posted by cokolo View Post
    Hi DK mate, very sorry to revive this old thread but I'm facing the same problem, I need to program this Ford Ranger odometer but don't have any idea for the connection attached..where is that 1 and 2 connection going? I'll be using UPA, what chip should I select?
    TIA
    Aug 2010
    Thanks every Dk mate help me.
    May i use tacho or x-prog(clone)
  8. #6
    Jan 2011
    Quote Originally Posted by Dylan Chin View Post
    Its hard to use xprog with that chip, i would prefer upa for this one
  9. #7
    smartymarti's Avatar
    Jan 2011
    cornwall
    Yes you can use tach clone
    All about the Bass
  10. #8
    May 2011
    hi
    yes with tacho clone put wires like the post above show and select ranger 05-,then it show u ??????? as old mileage which is ok and put new miles data will be in miles so if want in km convert to miles and put as new value and press ok and after 20 sec. trip become activate in the display of cluster and programming done.
    Thankx
  11. #9
    Aug 2010
    i solution the problem..thanks
  12. #10
    Aug 2010
    everybody,i got a new problem.
    The mileage problem is solution
    but after i assembles the meter ,start the car
    the Injectible oil emulsion,rpm..will up but dont down
    what the problem about this?????
  13. #11
    May 2011
    hi
    u did with upa usb programmer or tacho clone???
  14. #12
    Aug 2010
    i use tacho clone
  15. #13
    Aug 2010
    Hi mate,all the meter working now exe speedometer.
    i have resolder all ,i have try 12v positive and negative on table,the speedometer will move but at the car the speedometer not working.
    did someone teach me how i solution the problem?
    help!!!!
  16. #14
    calin_bm's Avatar
    near civilization
    same problem also on me,the RPM needle stays down, anyone deal with it and how did he solved?
    verry anoying....
  17. #15
    bluedid's Avatar
    Mar 2009
    Greece
    Quote Originally Posted by calin_bm View Post
    verry anoying....
    I have also the same problem http://www.digital-kaos.co.uk/forums...2004-a-255035/
    have you solve it?
