Results 1 to 15 of 29
    Jun 2009
    Default DAEWOO LANOS ,im710 ,hybrid ecu
    i have a daewoo lanos that do not start . after of return the ignition the car starts .
    it looks like to be the immobiliser im710 with memory 93c56b.
    i use a emulator of ecutool but not work either .
    i check memory and the keys exists.
    i do not have communication with ecu.
    does anyone has similar problem ? is case to be the ecu that do not accept the immobiliser code?
    This emulator don t work in hybrid ecu and like Siemens Fenix 5 with Tms 374 ecu but only in ecu like Siemens sirius 32 which is in Matiz . I tested in the past in all cars Daewoo .
    Szczecin;Poland
    Open the ECU, you will find two SOIC8 parts, one of them is the ST 95020 eeprom (it's marked with ST logo). Read and post dump.
    No army may enter that land
    That is protected by polish hand
    Unless you are 40 to 1
    Your force will soon be undone
    Jun 2009
    its hubrid ecu i do not think to see the logo st but just a hubrid memory st.
    here id the pdf of emulator i use .the immo box is the same with mine in the car.
    has anyone manage to work this ecu with emulator ?
    As i said before this emulator don t work in this ecu . I tested in the past . Open the ecu and desolder 8 soic 95020 and upload it . Don t waste your time with this emu .
    Jun 2009
    thanks antlio for your time but the customer was on hurry with car and not have time to do this . do you have any photo of ecu opened, original file and immo of file to do this the next time?
    Jun 2009
    HERE IS a file 95020 can someone help me?
    Jun 2009
    someone can help?
    Szczecin;Poland
    Yes
    This file should help you.
    Quote Originally Posted by bugajewski_pl View Post
    Hi m8
    i have the same problem. I have opened ecu. I can see two soic 8 chips, but which is the right one? 1 or 2?
    regards
  11. The Following User Says Thank You to IchBins For This Useful Post:
    honingkoning (10th February, 2017)
  12. #11
    Szczecin;Poland
    Number one is 95020.
  13. #12
    ok thanks,
    i was not sure, because name 95020 were not.
    Here is Dump from 95020.
    many thanks in advance
  14. #13
    Szczecin;Poland
    Check this file, and report results.
  15. #14
    Thanks!
    I will test it on Monday and then report here.
    regards
  16. #15
    OK, now after a small accident I am again in top form.
    So, it does not work. But it lies, perhaps, in the ECU.
    The ECU it is perhaps defective. I have exchanged them together with the Immobox.
    The car now work.
    Thank you again!
