Hello friends. I am interesting that does OPENBOX S10 support DVB-S2/8PSK?
Special thanks for replying, but i have got an openbox s10. I cannot recieve DVB-S2/8PSK signals.
to tell you the truth m8 i didnt check although i dont see why not and havent seen any other owners with your problem. ive had a look at the specs and it doesnt say. which channels are you trying to recieve?, does the openbox not have the qpsk/8psk selection in the channel scan menu,s? regards mdt
DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
tried Sly Cinema Hits HD on hotbird, which i beleive is in that format and scans in and opens ok
@delovoy, check your signals are spot on as dvbs2 signals are more prone to drop outs than dvbs.. escepecially dvbs2/8psk from what ive read in a dmm clone section of another forum. regards mdt
Thanks friends. But for example on hotbird 11785 H DVB-S2/8PSK - 29900 2/3, 12341 V DVB-S2/8PSK-29900 2/3 and other DVB-S2/8PSK signals cannot recieve. Maybe i must change settings in the scan menu? What can you say?
Hello, I have an S11 Skybox, equivalent to a Openbox, but I can channel to be received no DVB-S2/8PSK. Did I did something wrong?
hi
i have a openboxs9 and i am living in north africa but i meet some hassle with my receiver because it's can't get some Dvb-S2 frequences such as the both you quote but i got this DVB-S2 frequence 10911 V 27500 3/4 8PSK even thought the signal is weak compared to DVB-S frequences.
So i noticed the openboxs9 has not a very sensitive tuner.
Hallo,
How is it possible to see if the transponder is wll configure for DVB-S2 8QSK
Indeed, few stations from TELESAT Belgium are on HOTBIRD 11681 in DVB-S2?
How to control if my Openbox S10HD has the right settings for that ?
