Results 1 to 4 of 4
    Top Poster powered by's Avatar
    Oct 2010
    Germany
    Default EDC15C4 vw Lt 2,8 Problem!!!!
    Hi folks! All someone has worked with the ecu bosch 0281010588 edc15c4? I have a client who wants to turn immo off a transporter Lt. 95p08 have read the eprom, I try to record an immo dump off, I found the forum, but do not let burn. I'm thinking if there are ways to work on the 29F400 flash? I have not read in this that the VIN, and not even this number of immobilizer. Here attached the dump of the flash reading, if anyone can help? Thank you very much and good day!
    Oct 2010
    Germany
    Hello youngs , pls Help!!!!!!
    Dec 2010
    Ro
    must look b58253 = 24c02.read ecu and post dump.
    Oct 2010
    Germany
    Hello Emanuel ! hola Emanuel! Thanks .
    No 24C02, only the signature 5P08C3 ST. You can send the dump, but there are very few models with this eprom. Also try to mount a 24C02 but it does not work, I think there is something in the dump of the 29F400 that is not the number of frame, nor the number of immobilizer, as if they were deleted. greetings Juan Carlos
