Results 1 to 15 of 15
    Member trent1579's Avatar
    Oct 2010
    Default how to: vlc player to dreambox
    hi guys,
    setting up vlc player and dreambox can sometimes be tricky,with these simple tips you should overcome any difficulties.
    im using dm800 hd
    gemini 5.1 ssl 82
    vlc player on my pc is 0.9.6 version older/newer versions for windows can be found here
    Index of /pub/videolan/vlc/
    install vlc player on your pc select custom install and select all boxes and close program for now.
    now lets install vlc client plugin on dreambox
    vlc client (dreambox plugin) is provided in rar below, download,extract and send IPK file to tmp folder using dcc e2,find the tmp folder on using dreambox and install ipk and reboot,vlc will now be in plugins
    or simply use ts panel or tunisiasat this may be easier for newbies not familiar with manual ftp set up
    set up the vlc plugin on your dreambox
    press green button
    select vlc
    press green button (add server)
    server address: pc ip address
    movie directory :change to folder on your pc where your movies are kept Example c:/movies
    press ok
    press blue button (set default)
    now open vlc player on your pc/laptop
    select tools
    preferences
    input/codecs
    change server default port to 8080
    save and close
    select tools
    select web interface ( you should always select web interface first before using the dreambox vlc plugin)this will stop crash log green screen on gemini image
    you should be now set up.
    select green button
    select vlc
    you should now see movie folder on pc
    use the ok button on remote to select files
    dont use blue button (play video)
    * you will need to select web interface everytime you start vlc on your pc/laptop before using vlc plugin on dreambox
    *you control the movie fast foward rewind pause etc via the controls on your vlc control panel on the pc/laptop and not on the dreambox remote
  2. The Following 2 Users Say Thank You to trent1579 For This Useful Post:
    maltamim (19th October, 2013)
  3. #2
    Top Poster + damiensk's Avatar
    manchester
    have managed to record from my dm to my nas hard drive, and then watch what is recorded on my nas via my dm.
    my question is, am i able to watch films i have d/l on my nas drive ( avi format) via the dm vlc player, have tried doing what trent1579 says, but having no joy.
    the image i am currently using is a nabilosat blackhole v 0.12.
    can play the films via my pc from the nas, but i wanted to eliminate turning my pc on, and use the dm instead.
    any help will be appreciated
    Sep 2011
    Let's see if I've got this right.
    These instructions are to set up VLC on your PC to serve video files from a directory (folder) so that a VLC client on your DM can view them?
    Isn't it just easier to make your PC directory sharable and then use the Media Player on the DM to navigate that shared directory and play whatever you want.
    Oct 2010
    Default re
    hi guys,
    you require vlc plugin on your dreambox and vlc installed on your pc/laptop
    the method is tested on gemini 5.1,i do not know if it works on edg,nabliosat,cvs,sifteam etc as all images slightly differ in functionality
    Nov 2011
    hi there is no webinterface in tools menu
    Oct 2010
    Default re
    web interface on your pc/laptop
    Dec 2011
    im trying to setup vlc player.i have it in plugins on dreambox 800HD with Enigma2 Blackhole image but when i follow this
    and when i go back into plugins and press on vlc on dreambox it continually tries to open vlc but does not and i have to pull plug on DB as DB crashes and no control button will work untill i pull the power.seems like its trying to connect when i press on vlc but just loops untill i pull the power switch
    any idea how i can get vlc to work so i can view movies from my pc
    Jul 2012
    is it possible to download vlc plugin directly from dreambox?
    i can't find it when i search for new plugins on my dreambox
  10. #9
    Newbie blue knight's Avatar
    May 2012
    regarding set up the vlc plugin on your dreambox i got as far as{ movie directory :change to folder on your pc where your movies are kept Example c:/movies} finding it impossible to do this with remote control is there another way to do it
  11. #10
    Oct 2012
    How to install in manual/FTP way?
  12. #11
    Dec 2012
    How to install this
  13. #12
    Oct 2010
    Hi tried this software does everything very easy to set up licence is about ?5. Streams dreambox plays recorded programs from hdd must say I am quite impressed.
    Watch TV Anywhere ! : Enigma TV
    Its uses vlc player in the background and will also act a server if you have an iphone its a bit like airvideo.
  14. #13
    Apr 2011
    Hi All,
    On my VU+ Uno all I do is, Load Uno's IP Address
    Press enter, Pc connects to Uno then the virtual
    remote page opens (OpenWebif, Image Openvix).
    Chose channel Click open, minimize picture. stick
    it in the pc monitors corner.
    It will also move dish from sat to sat.
    can use VCL any were in the world with laptop to
    view any channel on Uno. (If Uno is in Standby)
    No need to load VLC into Uno, just install on PC.
    BF.
  15. #14
    Mar 2012
    Quote Originally Posted by markshore View Post
    I have a DM500S, image is Commando V14.6, connected to my router using a Wifi Bridge and have been trying for ages to try and watch the box on my PC (using VISTA) but no matter what guide I use I just can't get it to work.
    Does the software from the above link actually work?
  16. The Following 2 Users Say Thank You to pjmorie For This Useful Post:
    duronur2005 (21st June, 2014), maltamim (19th October, 2013)
  17. #15
    Jun 2019
    Quote Originally Posted by trent1579 View Post
    hi guys,
    will it work with pkt?
