Results 16 to 30 of 36
  1. #16
    Top Poster tonynw's Avatar
    Nov 2011
    N/west
    Default s10 manual
    Quote Originally Posted by ankobluebird View Post
    I really need this manual, but why the dun provide it on the box as well?
    send me your email add and i will send it to you also have the s9
    tonynw
  2. #17
    Newbie levais's Avatar
    Dec 2010
    HOW TO SAVE TO -(U disk root list)
  3. #18
    Jan 2012
    Default Thank You !
    A big thanks for the manual.
    Can anyone help me with the manual for skybox S11 ?
  4. #19
    Jan 2012
    Default s12
    will the maual apply to the s12
  5. #20
    Feb 2012
    Default how do i cinfigur the skybox in malaysia
  6. #21
    Feb 2012
    Big thanks for the manual.
    Does anyone have usermanual for s11?
  7. #22
    Apr 2012
    Anyone has problem with the S12 signal? Mine will start having problem and picture stop display especially at night. Please help.
  8. #23
    Jul 2012
    can anybody send me open box manual?
    thanx a lot for helping.
  9. #24
    Aug 2012
    Default thanks for this nice forum
    they should ship it with the box , thats strange bot to do
    thanks for that
  10. #25
    Aug 2012
    Default Skybox F3
    I've found out how to record to USB, but how do you play from the USB. And is the F3 S11 or S12?
  11. #26
    Nov 2012
    Default Help with skybox
    Hi there, i am still new in this. I understand that we need a server for the skybox to work? My question is can we set up our own server? if yes, how?
  12. #27
    Dec 2012
    thanks to you
  13. #28
    Jan 2013
    thank you very much
  14. #29
    Jan 2013
    Thanks for the great info..
    I have a question..
    Where can I change the passcode?
  15. #30
    Jan 2013
    Default channel list
    Quote Originally Posted by darvash View Post
    As almost all the skyboxes and openboxes are shipped without any user manual. If anybody needs that
    You can download it her or from attatched pdf doc.
    openbox_skybox_User_Manual.pdf
    How to edit CCcam+ Newcamd accounts & MGcamd Plug setting Openbox S9
    This part is taken from another forum so thanks to author for this tutorial
    CS share protocol settings.
    Edit CCcam+Newcamd accounts
    1. Prepare an available Cccam code like this
    C: test.dm700.com 63001 user100 password100 yes
    N: test.dm800.com 12000 user1008 password102 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    2. Use Wordpad to open Cccam.cfg file , and copy the available code into the wordpad and save it.
    3. Then copy the Cccam.CFG file with available code into your U disk root list.
    4. Connect the USB drive to HD Box usb port
    5. Press "menu" into Cccam setting ,select Cccam Plug Setting and OK.
    6.Select read CCcam.cfg From USB and press OK.
    7. After reading account, please select Account Management and press OK.
    Activate the sharing accounts and reboot the receiver
    9. For MGcamd Plug setting.
    10.Edit and Copy the replace.lst and Ignore list to U disk root list, then press " update replace.list by USB device or Update ignore.list by USB device" to load the files and save the files to STB.
    12. Network Local settings:
    Select Network Local Setting and press OK.
    13. At DHCP select "ON" and then select "Apply" press OK.
    So the sharing setting is now finished.
    How to make Openbox /Skybox work as a server
    It couldnt be easier.
    1. Press "Menu"
    2. Scroll down to "Network Local Setting"
    3. Press "OK" on remote
    4. Arrow right to "Newcamd Server Settings"
    5. Press "OK" on remote
    6. Enter newcamd server parameter
    7. Server setting -ON-
    8. TCP Port -eg. "13000" this must be forwarded in your router
    9. Des Key 01 02 03 04 05 06 07 08 09 10 11 12 13 14 (Can be change to your own)
    10. Add USER in Newcamd server User manager with green button on remote
    11. Add username PASSWORD "Allow emm YES"
    12. Press yellow to save the configuration .
    Now box is setup for server with 1 client and a reboot is always a good idea .
    In the Client box with CCcam its the N: line to use for acces the server eg
    N: server_ip_or_dns 13000 USER PASSWORD 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
    Please don't forget to leave your comments about it. You are also free to use the thanks button
    do you have a channel list for openbox
