Results 1 to 15 of 20
    jackeldestripador's Avatar
    S.A.
    Default MM 6PLB PINOUT FOR XPROG
    Hi folks maybe this can be helpfull for someone. I was looking for connections of XPROG for Magneti Marelli 6LPB ecu but not found. I have some burned ecu and other working well so i remove the st chip and check for some wirings. Work fine in xprog.
    Please not forget say Thanks!
    p.s.: .rar file are the images more bigger.
  2. The Following 35 Users Say Thank You to jackeldestripador For This Useful Post:
    abdou elec (2nd January, 2015), AIRBHENRY (21st May, 2020), alefabi2006 (29th October, 2014), banabana (26th January, 2015), brahimdyag10 (19th December, 2017), BusCan (28th April, 2022), Cardump (2nd February, 2019), carlab237 (29th July, 2018), dadal (19th December, 2017), darwins (22nd May, 2013), derbali01 (28th December, 2017), DSAuto (17th September, 2013), dzamine670 (29th June, 2018), estwood68 (9th October, 2020), hhp (19th November, 2019), icc (10th November, 2015), ioolo (21st December, 2017), kierownikszatni (23rd March, 2015), konarg (14th October, 2013), magdex (6th November, 2014), magicworx (24th May, 2023), MARIKO (16th December, 2017), mohamedkey (6th November, 2014), NiZaTroniC (26th March, 2015), OFFIMO (29th January, 2015), poze1977 (14th December, 2020), rafalkama (20th September, 2021), ratso77 (29th April, 2019), sancaman (31st December, 2024), Silver740 (1st August, 2019), tamer1024 (22nd November, 2019), taxi300 (9th June, 2016), Toutancamon (23rd February, 2016), youssef70 (17th February, 2015), ZYX (25th September, 2013)
  3. #2
    ALGERIA
    I have open a thread for bdm connection for xprogm
    http://www.digital-kaos.co.uk/forums...xprogm-218551/
    and it will be very helpful for all ,to update this thread with your connections
    in the end,we will get all XPROGM connections for all ecu
    thank you
  4. The Following 4 Users Say Thank You to grinovsky For This Useful Post:
    carlab237 (29th July, 2018), derbali01 (28th December, 2017), DSAuto (17th September, 2013), JAZO (2nd December, 2019)
  5. #3
    S.A.
    Thanks you grinovski!! Thats the idea, together we have more knowledge.
    I have some other connections for Delphi ecu but i don't have the xprog permissions to read mc555 processors. Later i will post it.
    Thanks!
  6. #4
    S.A.
    Does anybody have some virgin complete file for this type of ecu? (IAW 6LPB HW 16.707.154 SW 16.814.034)
    Thanks!
    S.A.
    For the record, i have found some virgin ecu works fine. Please check if any can write to some 6LPB ecu using xprog. I can't write, only read. I've tryed erasing all and writing but no success, only with st10 flasher or other similar.
    Here is the virgin dump. Thanks!
  8. The Following 10 Users Say Thank You to jackeldestripador For This Useful Post:
    Abdo Abdelatif (11th May, 2018), abdonete (30th August, 2015), AIRBHENRY (21st May, 2020), carlab237 (29th July, 2018), DSAuto (17th September, 2013), estwood68 (6th October, 2020), JAZO (2nd December, 2019), JuamPa16 (5th December, 2019), nadhir (1st September, 2019), tamer1024 (22nd November, 2019)
  9. #6
    Default help
    Quote Originally Posted by jackeldestripador View Post
    how to convert bin file to hex file
  10. #7
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    tested ok thaaaaaaaanks
  11. #8
    rabie_m's Avatar
    Jun 2009
    morocco/sale
    Quote Originally Posted by 3abas27 View Post
    convert of winhex
  12. The Following User Says Thank You to rabie_m For This Useful Post:
  13. #9
    Quote Originally Posted by rabie_m View Post
    convert of winhex
    thanks freind rabie
    pls winhex or winols for converting?
  14. #10
    Philippines
    Hi:
    I'm trying to read an ecu 6LPB with your connection but i have a pin vcc overloaded. Can anyone help me with the correct connections please?
    Thank u
    BR
  15. #11
    Apr 2011
    France
    Default I need immo off IAW 6LP1.40
    Hello
    If possible, make me an ecu immo off for an IAW 6LP1.40
    I'm in trouble my friends
    thank you very much
  16. #12
    Apr 2012
    Default HI Friend
    please I can know what it is ( p0 4 )
  17. #13
    KACZANUK's Avatar
    Brasil
    Which interface u used to make this reading?
  18. #14
    Nov 2014
    muchas gracias campeon
  19. #15
    Nov 2014
    espero les sirva de algo compa?eros.
  20. The Following User Says Thank You to romanmartin For This Useful Post:
    carlab237 (28th October, 2018)
