change windows system regio setting to US.
http://www.part.lt/img/09a11c0a93b0f...0097bc2342.png
as you can see in the screenshot, for some reason winols command window has very small font (impossible to clearly see any of the code), tried reinstalling it, tried changing font size and font type through settings, but it didn't work
maybe any of you had the same problem and know how to fix it?
works fine for winxp. try compatiblity mode.
never tried it on vista or 7
problem is the installation. try a different setup + different loader.
change language settings to English (try UK and USA)
Start winols, go to menu where you can change the settings.
There look for the name of the font winols is using...
Now go into your fonts-directory (depending on your windows-version where you can find it - just google for the location on your system) and DELETE (or rename) the font winols is using!
Now you can restart your COMPUTER and winols should use a other font where you can adjust the size correctly!
BTW: Please dont forget to press the THANX-Button if it had helped you!
1. You should Backup 3 Fonts in C:\Windows\Fonts
to a new Folder.
Dejavusansmono.ttf
cour.ttf
lucon.ttf
If you dont have this Fonts , download Fonts.zip .
2. Start Winols 1.500 and go to Settings / Fonts
chose Dejavu as normal 16 pix.
Press ok
close Winols
3. Open Fonts Folder and delete all 3 Fonts.
Now you should have an usable Winols.
Please dont forgot to say thanks if this helps you.
(tested on Windows XP)
