iPhone 4 no signal
Results 1 to 15 of 25
    Default iPhone 4 no signal
    i have an iPhone 4 with no signal but the carrier name is showing i have tried reseting all settings from the settings and down a restore of the phone back to factory settings but still i get no signal bars but carrier name VodafoneUK shows
    after a google search i cant find anything to pin point the problem if anyone can shed any light on this that woyld be great thanks .
    p.s it's not stolen or barred etc
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    have you tryed truning off 3g to see if it kicks it
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
    DK Veteran fijiman's Avatar
    Oct 2010
    Wales
    Quote Originally Posted by Jo-Jo View Post
    Can you make out going calls regardless no signal bars..? is it still in warranty/worth checking with Apple...,are you running any app that hides the signal bars..?
    if it under warentty take it
    to apple
    job done
    no calls fail in and out and it's out of warranty with apple
    Jul 2008
    is it the same sim card you got with the phone ??? all so have you tryed 3g off
    Canker_Canison's Avatar
    12th Level of Hell
    Have you called your network to check if the IMEI has been blacklisted?
    Just because you have not reported it doesn't mean a fcuk wit in a call centre didn't press the wrong buttons.
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
    as i understand if its blacklisted it would state no service and not my carriers name
    DK Veteran johnboy1974's Avatar
    glasgow
    jo jo i agree with canker it looks like its been blacklisted or could be a faulty sim card also. I had one that was blacklisted and carrier did show up but no reception bars.
    have contacted vodafone this evening and it is not blacklisted .
    12th Level of Hell
    Ok, do you have the all important rubber band around the side?
    Has it been anywhere near water or have you handled it with wet hands?
    I think it's going to be a trip to a repair shop. But depending on your answers & how brave you are, there may be things you can try.
    Canker
    [COLOR=Green]
    Oct 2010
    Wales
    The phone has not been unlocked? Have you had from new? Myself I would book a slot with the Genius bar and milk it for all it's worth... regardless the warranty has expired... Apple have been known to swap the iPhone for well known documented problems. you have nothing to lose.
  13. #13
    Aug 2011
    I thought I was the only one! phheeww hehe..
    Well same problem as you..
    Iphone 4, unlocked at the phone shop where it was bought (Oh I live in Copenhagen, Denmark). I updated the iphone 4 through Itunes to IOS 4.3.5 BB 04.10.01 and there are no signal bars. The carrier (Telia DK) is found and 3G is available which mean I can surf on the net, check mail etc. but there are still no signal bars. Everything works except the phone and texting part because of no signal bars! not jailbroken btw! Tested with 3 different SIM cards from 3 different Carriers. Same issue.. Any suggestions?
    Thanks.
    /Duc
  14. #14
    DK Veteran lee_hdi's Avatar
    Sheffield
    They all sounds IMEI blocked to me
    I had one on O2, that was IMEI blocked but O2 still showed. IMEI is blocked by Apple not your carrier, and they can't unblock it.
    If anyone wants to sell any, give me a shout.
  15. #15
    Oct 2010
    Wales
    Quote Originally Posted by ducmphung View Post
    Thanks.
    /Duc
    The very fact it was "unlocked" and you updated the BB through a firmware upgrade to 4.10 points to the problem.
