Results 1 to 3 of 3
Hybrid View
    yellowstilo's Avatar
    Nov 2009
    Default driver(s) for MPPS v. 8.0.2.10 interface
    hello,
    i just received my MPPS 8.0.2.10 clone from Belarus - after installation of the belonging software i plugged in the interface but in Device Manager it shows as a Human Interface Devices / HID Compliant Device / USB-HID
    it shows these drivers were installed which i suspect to be the wrong ones:
    C/Windows/System32/Drivers/hidclass.sys-hidparse.sys-hidusb.sys
    C/Windows/System32/hid.dll
    could someone with this version please check what drivers belong to this version and please post them here with their map location?
    The program does not open - i guess that's because the interface is not recognised?
    thanks a lot for your help, i hope i will get this interface up and running as it was too expensive to put it in the drawer with the other non-working tools....
    Jun 2010
    Hi!
    You need to uninstall the drivers with these PiD and Vid from the system (the utility FTClean.exe) and re-install the correct driver.
    Good luck.
    Nov 2009
    Quote Originally Posted by 8k65m View Post
    Hi!
    Good luck.
    If i understood the FTclean instructions well this utility erases all FTDI drivers and you will have to reinstall all FT drivers again?
