Hi Guys!
I would have to clear the crash data from a Vectra C.
The airbag ECU is GM 13 142 540 GP.
I've attached the dump form the original M95040.
Regards,
Tibi
Hi Guys!
Regards,
Tibi
horsepower (17th April, 2013)
Should be fine.
br
this is going onto my nerves...
I've tried both files, crash data was removed no code present regarding that. I've did the CAN coding. But when I tried to do the airbag configuration it always gives the error: "coding unsuccessful"
Is there a certain step by step guide which I would have to follow?
(using opcom)
Look here: http://opcomforum.yolasite.com/guides-and-info.php
Probbably something like that:
Corsa D
- SDM TEMIC
- Program the V.I.N. in the SDM module.
- Program the CAN module configuration in SDM.
The SDM module is part of the Corsa-D immobilizer-system and the car will not start until
SDM module has been matched.
- Program the Security Code in the SDM module.
- Program the variant configuration of the SDM module.
When the configuration is programmed and the error codes are cleared, the error code light
should still be flashing, and the following code is stored:
B1001 : 46 airbag module not locked
- Start the Self-Test and if no other codes are found lock the SDM module.
If you find other codes, investigate whether to configuration is wrong or there is still a fault
on the vehicle
Note
After locking the SDM module the configuration can not be changed. Only the seat belt
warning indicator can now be put on or off.
Astra H / Zafira B
- SDM TEMIC
B1001: 46 not locked airbag module
- Start the Self-Test and if no other codes are found lock the SDM module.If you find other codes, investigate whether the configuration is wrong or there is still a fault
on the vehicle
Note
Thanks Mate!
I've checked that, but it doesn't really show anything special for the Vectra C!
Just programme the CAN config, and then the aribag config, and lock the ECU. CAN config works, but when configuring the airbags it gives error, saying: programming unsuccessful!
Tried it again today! NO LUCK
Programming failed again!
Please help me!
Another for test.
br
your dump cleared
Thanks Guys!
Tried the file from morfej, and again it didn't work
Then I received a dump from an other site which worked at last! - so I did not try the dump from Shmortz!
Hello please....I have the same problem also... could you send it to me please.
Thanks.
