Results 1 to 9 of 9
    kautuvera's Avatar
    Sep 2009
    Default Ford VCM Communication error
    I first want to use this Ford VCM unit when connected to the computer gives me this error. What is wrong with you?
    thanks in advance
    Apr 2010
    If I had to guess. I would say cable from pc to vcm is bad.
    kautuvera's Avatar
    Sep 2009
    Reinstall the operating system was the problem
    May 2010
    Russia, Saint-Petersburg
    Hello,
    I have same problem.
    IDS cannot see VCM. I checked on 2 different PCs. Used other complect of cabeles. No sucsess. So I think problem in VCM hardware.
    Any ideas, what I need check in VCM - resistance ets...?
    barti122's Avatar
    Nov 2009
    Poland N
    i have this same problem
    Jun 2009
    Default VCM IDS
    me too have same problem i need help thanks
    Apr 2012
    Saudi Arabia
    Quote Originally Posted by doome View Post
    install 76 and try
    V76 if its ask for activation code send me PM
    Apr 2012
    Quote Originally Posted by kautuvera View Post
    thanks in advance
    contact me if your problem software .i make a solved your problem...
    diagnostamir
    kautuvera's Avatar
    Sep 2009
    The problem solved was to reinstall windows
