DO NOT KNOW
Hello to all members ! There is a plexer and can not communicate with. When you join you can see the power car but the Communication does not come l?tre.B?rmif?le help would be great.
Have you tried FindChips.com Online Electronic Component Distributor Inventory Search ???
They have both.
Maybe it help someone for repair Caesar
Hi.
Please C3 interface serial cable pinout.
Thank you
Hello, resoldering the components on all 3 pcb's of Chinese MUX C4 sorted the problems for me.
Hello, I got the same mux as the one posted on first page and I'm wondering if its correct that the U103 and U107 should both be MAX232? Are there no RS485 tranciever?
HI people !
I got this C3 to try to fix !
I have install native acronis image 9.2013 but no luck to connect C3 width PC !
I cut the wires of the cable and put one max232 in mux pcb !
here some pics !
any one have try it made this ?!
is the connections good ?!
BR
My work is my life ART TECH GARAGE
OK !
now the PC and Xentry see the MUX !
today I solved problem of DAS key !
and green bar again !
BR
HI again !
I found the sheme to conect diretely to the pcb of the C3 !
Only 8 wires use in COM port pins 2-9, pin 1 is not use, and pin 9 must be conected with pin 4.
Pinout of 10 pin for round cable:
1 - GND (to pin 5 COM)
2 - Vcc to adapter
3 - Tx+
4 - Tx-
5 - Rx+
6 - Rx-
7 - to pin 6 COM (DSR)
8 - to pin 7 COM (RTS)
9 - to pin 8 COM (CTS)
10 - to pins 4,9 COM (DTR,RI)
Do not use pin 2 (Vcc), find wire to pin 14 U107 and conect to pin 2 COM (RX),
find wire to pin 13 U107 and conect to pin 3 COM (TX)
but here in the midle box o the cable is diferent !
see midle pic of post before
come on guys, no one does trick"s on is on tools ?!
Hey guys any idea why K line not working when trying w203? CAN working perfectly, but k-line not, cannot enter in any module?
