Results 1 to 15 of 16
    Default dpf off for grand vitara
    can someone remove the dpf in this car grand vitara 2006 year edc16 .
    thank you in advance
    regars
    once did vitara 1.9 DDiS 131 HP ecusafe work ok all the sensor must be plugged,laguna engine
    i tryed whith ecusafe but dont work i try whith suzuki edc16 and renault edc16 whith 2.0 and 1.9 ecusafe but dontt remove the dpf can you help me whith youe ecusafe please
    post full bdm file
    Default full file
    i read whit dim sport the full file is .DIM here you are
    macxlulu have you the same problem ?
    soundnavigator's Avatar
    Sep 2010
    I made several of these without a problem, but the latter have a problem and error P0606 and some new errors. I read and write only flash file with calculated chs. The car runs but has little power and has the following errors
    P0110/CO.1
    Intake Air Temperature Sensor 1 Circuit
    Intake air temperature sensor 1 signal low or high input (CO.1 ? Open circuit or short circuit to +12 V
    P0100/D2
    Mass or Volume Air Flow Circuit
    2.DEF ? Offset at minimum threshold
    P0606/D6 ? replase!
    ECM/PCM Processor Malfunction
    Engine control module internal faulty (system error)/ 6.DEF ? EEPROM fault
    P0638
    Throttle Actuator Control Range/
    Performance
    ? Inlet throttle valve actuator circuit shorted to ground circuit
    ? Inlet throttle valve actuator circuit open or shorted to power circuit
    ? Inlet throttle valve position signal low or high input
    Anyone had any similar problem? Any ideas?
    Best regards.
    yes i had two cars whith this problem and i had to change the ecu.
    Quote Originally Posted by javilette View Post
    I would say the potential problem of checksum.
    Regards.
    Default a
    Quote Originally Posted by gezame View Post
    Regards.
    i dont change anything in those car read the original put in the used ecus and works ok
    Sep 2010
    Does anyone have any idea, can I use the ECU with number 0281012657 as 0281012569 for test. I will program with file reading from old ECU. They have the same hardware ? The two ECU have the same other number 8200518648 . Thanks in advance.
    Best regards.
    Someone can please remove DPF in this file
    Suzuki Grand Vitara 1.9 DDiS EDc16C3 1037382012P500_V50
    Try with ES but not work correctly
    Thank you.
  13. #13
    This is you file
    Pass in PM
    Dont forget to click thks
  14. The Following User Says Thank You to jmush303 For This Useful Post:
    haingoben (19th July, 2014)
  15. #14
    DK Veteran haingoben's Avatar
    Dec 2011
    Tana
    Hi, can u share to meet the Pass please!
    Thanks!
  16. #15
    Dec 2011
    Tana
    Default dpf
    hi here my file
    please make it dpf
    EDC16C3 vitara 1037377494 has AM29BL802CB.rar
