Please can someone give me pin code from engine Ecu from this 2000 1.8T petrol bosch 0 261 207 030.
Is it calculated with algo or is it hidden in the hex file
Thanks to all.
Thanks to all.
in this ecu is not pin code you must read from odometer MM procesor hc12
Thanks for info, here is mm4, dash 912 dump.
Could someone give me pin
Thanks again for all help,
The keys coded in as in system 1, but i always thought that if the car had the "key in car" symbol on the dash it was system 2. however, i coded in all 4 keys, but for some reason the "key in car" light is on constantly now, although all the keys start and run perfectly, and i've left a couple of minutes between swapping keys. there are no codes stored so what is wrong? the light wasn't on before i coded in the keys with the correct code ?
erase trouble code in the injection ecu if still on try to erase all keys and adapt again.
Thanks to all, Magically this morning light is out all is fine without touching it.
DK is the best !
btw: you can read TT login via obd with this soft and K line adapter
