Results 1 to 5 of 5
    Aug 2011
    HULL
    Default can?t get satellite signal on my first set-up
    I live in High rise flat with a communal satellite connection
    I have attached leads from SAT 1 to LNB 1 IN
    SAT 2 to LNB 2 IN
    from my satellite wall plate output
    to my BOX
    The Wizard searches for the satellite signal but reports icannot find signal check connections
    ....the connections seem to be OK
    My leads are F Plug To F Plug Satellite Cable Coaxial Lead*
    from
    Play.com - Buy Cable-Tex F Plug To F Plug Satellite Cable Coaxial Lead Black 3m online at Play.com and read reviews. Free delivery to UK and Europe!
    my BOX is
    Humax Foxsat HDR 500GB Freesat HD Satellite Receiver and Digital TV Recorder
    any clues to get me started < please
    Sep 2008
    are you sure its not a cable provider your with
    Jun 2009
    If it says sat1/2 on the wall plate it should be for satellite.
    any chance you can check your box on a neighbors or check a known working box on your wall plate.you could also ask the flat manager if your outlet has been disabled.
    Aug 2011
    HULL
    Quote Originally Posted by cactikid View Post
    i still thinks its an satellite atenna.....might be faulty distribution box on the wall neighbour thinks not wired up etc
    cheers
    Aug 2011
    HULL
    Quote Originally Posted by dick b View Post
    Good Idea!
    might be dodgy
    cheers
    he thinks ive set it up OK
