Results 1 to 15 of 17
Hybrid View
    Member Borgy100's Avatar
    Aug 2010
    Baile atha Cliath
    Default MGcamd 1.35 running well on my itgate
    Hi all,
    Just thought I'd add this for those that might be looking for an alternative to CCcam (some reports that cccam not the most stable emu and can be glitchy). I had been getting a slightly glitchy service and was recommended to try this alternative.
    I downloaded mgcamd 1.35 from my cpanel, and newcamd.list (the config file) onto my box. did a bit of editing and ftp'ed to newcamd.list. Now have MGcamd running almost fault free on same server. Still have cccam active and when i swap between the two the difference is noticeable with less glitching.
    Anyhow...just a thought.
    B~~~~100
    Feb 2009
    Was that from my cpanel m8? just wondering because I couldn't get it to work, .
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    If it mgcam1.35a on its own youll need to download the config file aswell or it wont work.
    Have mgcam on 2 of my DM800s and CCcam on itgate,dont think CCcam will clear pick TV and mgcam will unless its been fixed since.
    Freck
    Aug 2010
    Baile atha Cliath
    Hi guys,
    not from deeboi's panel I'm afraid..sorry Deeboi. I am running Edg nemesis with a fantastic 'extra URL' for a fully loaded cpabel. with all latest emus and config files for download via blue button. might be of interest deeboi for you to add to your excellent panel?
    Feb 2009
    I was always going to add extra stuff to the panel, just never got round to it m8. I might have to get my finger out and add some more content.
    Aug 2010
    Baile atha Cliath
    For those that want to play..
    here's the extra URL. it is for the edge nemesis 4.4 image. FTP to var/etc and chmod 755
    Top Poster Millzzy's Avatar
    Hi guys I gotta try this EDG image just to have a gander , what's the best way to back up my ukur image tried the backup prog In the sat image pack from freck but just hangs when don backup , can I just copy var folder through FTP if so is that the only folder I need to backup ? Thanks guys
    Aug 2010
    Baile atha Cliath
    Hi Millzzy,
    The itgate control centre 2.5 (in Freck's sat image pack) is the program to use. If its not working, I'm not sure how else to back up the image myself, but i would saythe whole image needs to be backed up and not just the Var folder.
    I have to say I have always used and preferred the UKUR images from my Satkings days, but the Edg nemesis 4.4.1 image runs and looks v similar, but the real treat is this cpanel...fully loaded and all accessible from blue panel. Was watching footie over weekend on s/y and no glitching at all with MgCamd 1.35a. Seems to be afar more stable cam than cccam 2.2.1 which i also have running.
    Sorry I can't be more help with the back up, maybe Freck, andiewill or plasterer will be around soon!
    Ok b~~~~ nice one mate , it's the epg that sounds slightly better on edg image , but me being me I can't help but have a mess , speak soon mate
    May 2008
    Quote Originally Posted by Millzzy View Post
    A few ways to back up...as you said save the "var" folder.....through ftp client...
    Or type your ip into the browser for web interface..press config,flash manager,then save the mtd4...the back up will be in the temp folder...ftp to the temp folder then transfer and save to your pc.
    For some reason i cant flash my ukur back up over the edge images...i have to flash the bare bones ukur image and then the back up.. this seems to work for me.
    good luck.
    Nice one mept , some great info there bud ;-)
    Feb 2009
    Anyone got the EDG image running on a converted TGC200?
    I couldn't get it to work on mines when I tried it but that was ages ago.
  13. #13
    Aug 2010
    Baile atha Cliath
    Quote Originally Posted by deeboi View Post
    Hi Deeboi,
    I didn't see you added to the bottom of the thread. I am running Edg Nemesis 4.4 on my TGC200 with swappable tuner. I have one of the early TGC200 silver boxes, and i got the tuner from Jono about 2 years ago way before Satkings closed up shop. Interestingly though, with the sat tuner in, my box will only flash TGM220 images!
  14. #14
    plasterer's Avatar
    Jun 2008
    Mersyside
    I got 2 220s here one running EDG one running uk 9
    But pretty sure one of our lads has a 200 working with EDG dee
    Fact i set it up for him 12 months ago ...................Paul
    PAUL
  15. #15
    Feb 2009
    Yeah B~~~~ I also have the original silver TGC200's and also got a Tuner from Jono.
    The problem I'm having with the EDG images is they won't move my dish, in fact they don't even send any power to my motor, the manual buttons don't work and there's also no lights on the moter either.
    Flash back to UKUR image again and works perfectly, .
    I'll give the TGM220 image a try later on m8, cheers.
    @Paul, can you remember who it was m8?
