Results 1 to 15 of 30
    Apr 2008
    Angry serious HELP needed PLEASE !!!!!
    i have a friends dbox and for some reason no matter what i do it doesnt work
    i was totally new to this 2 weeks ago but have now fixed a few relatives boxes but my friends dbox just doesnt want to play with me .
    i have treid everything the guys on here have said . uploaded the service boquets . fixed the au to 02 uploaded the nargorar 7 10 and 11 . more or less everything peoples have said .
    am i correct in saying that in the cam fg section the upload keys should be set at 02 .
    im starting to lose patience with it . kaous left a good post about delete the keys folder and download the link he posted then send it to the new box . \\would this be my best option now as i cant think of what else to do . thanks guys
    Apr 2008
    If you have got working box using the same image set up etc.
    Just backup the image and tuxfolder on to the computer then ftp them across to the problem box and redo.
    V.I.P. Member father ted's Avatar
    Feb 2008
    scotland
    did it work b4 all this?if so what have you done differently ?can you maybe take it to someone?or are you gonna try for it your self?
    aftermath's Avatar
    Mar 2008
    Think you need to be more specific mate.
    what is your problem ? does the box boot up ? do you receive any channels ? what image you using. e.t.c
    please give as much info as possible so peeps can help m8.
    Apr 2008
    oops just typed almost same as you aftermath.
    the boxes that don't work are they in the same area as the working boxes ?
    Apr 2008
    yeah the box goes on ok it boots up fine . i get the usual free view channels bbc itv .
    the image is commando . i have tried a scan but it didnt do anything . i cant think of anything i have done different .
    i set the au to 02 . and done pretty much everything i have been advised to . really want to try and sort it myself . like i said i done the other boxes ok and this one just wont work .
    thats the info i can really think off thanks for the replys guys
    V.I.P. Member Jaffa's Avatar
    Mar 2008
    Norn Iron
    Try flashing Laxy Pro to see if it is any different m8, some boxes just dont like some images. Dont forget to save your services and bouquets.
    Feb 2008
    scotland
    yea but was this the image that was on the box when it worked?if so what have you done to make it not work?apart from putting in roms and service and bouquets?
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    As Jaffa said m8 try flashing Laxy image or another updated image. theres a few out there now.
    Apr 2008
    check what cam you are using
    evo or mgcamd are ok others are (to my knowledge) not working.
    I can't remember setup on commando but check out blue button menu from memory.
    Also check keylist.txt for current keys or softcam.key if they are empty or wrong keys then you are prob using wrong cam or rom files are wrong
    Apr 2008
    I'm pretty much in the same, gonna try and flash Laky (when I'm allowed to download it )
    Apr 2008
    what is laky . and where do i get it from .
  13. #13
    Mar 2008
    Norn Iron
    Laky is in the downloads but just for your info...xenafan has realised a brand new image today called Blade Quad and its really excellent. You can get that below.
    http://www.digital-kaos.co.uk/forums...hp?do=cat&id=6
  14. #14
    Apr 2008
    thanks jaffa . so how do i send this to the box . i will download blade quad just now .
  15. #15
    Mar 2008
    Norn Iron
    Have you got flashfxp set up to ftp the image across ???
    If so then unrar it and ftp it to /tmp, then go to your remote control and press:
    dbox
    service
    image upgrade/update
    expert functions
    flash one patrition
    flash without bootloader
    pop up box will appear and choose Blade Quad then then enter and press red to flash.
    If you have not flashfxp set up then download flashfxp and guide with is in the guides section of dbox in downloads.
    Have you saved your services and bouquet files ???
