Results 1 to 8 of 8
    tiguan's Avatar
    Default Xprog-M Not Read_MC9SDG128E...HELP
    Xprog-M Not Read_MC9S12DG128E...HELP
    Have problem with reading Eeprom MC9S12DG128E, (Mask_0L94R) Selected Xprog-M_Clon.
    According to the diagram connected,Reading is not work
    Someone has solution to this
    Tiguan
    etl read sucesfil
    maybe mcu is secured are you tryed with bdm adapter?
    Can you try with UPA if you have it, with a hope that the MCU is not secured. If you've tried a lot but still failed, there might be a technical issue related to this mask set.
    I want to know how the thing goes with UPA, if it works I may be able to give some answer.
    What is the crystal freq. on the board
    tiguan's Avatar
    Default Xprog-M_MC9S12-Secured_Device [Hz]
    Quote Originally Posted by Zmann View Post
    Do not have a UPA-USB,I also tried several times
    secured with no success
    MC9s12-EEPROM Secured
    Oscillator [Hz] 4000000
    cjawahir's Avatar
    T&T
    Quote Originally Posted by antibisic View Post
    did you try it with the bdm adaptor ? and what fault do you get , cant see the picture , its too small.
    cj
    I would say that for this 'grouped universal menu, MC9S12-EEPROM-(secured or unsecured) and MC9S12-FLASH-(secured or unsecured)' the setting for CLOCK on the SW is not a concern, no need to set and can be any. But my interest is what the crystal on the board read? Better with good photos of your board, as well as photos of your cable I said in the PM.
    Just read more, your mask set has quite many errata from factory including one EEPROM read/write problem. Want to check that it can be your concern or not.
    what you read dash or EZS or CAS ..???
