Results 1 to 10 of 10
Hybrid View
    Post replace ecus (opel,vauxhall,holden,gm) it's possible with opcom
    it's possible replace ecu and immo with opcom chinese, and what i need know befor o do it, chassi nunber and pin code of the imo and ecu?
    astra,corsa,celta,meriva,vectra,montana,agile.s10, blazer.
    racin-snake's Avatar
    Jun 2009
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    DSAuto's Avatar
    Cape Town , South Africa
    The china Opcom works great.
    You will need both pincodes though - ecu and immo.
    DSAuto
    America
    Whit Opcom and the 2 pin codes you can first reset both modules and programm again with one pin code.
    dritan's Avatar
    Apr 2013
    Default replace engine ecu opel corsa c 2002
    i want to replace engine ecu x17 dtl opel corsa 2002 can i replace with opel com china?
    NASTASE's Avatar
    ROMANIA
    Quote Originally Posted by dritan View Post
    Yes, you can.
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
    dritan's Avatar
    Apr 2013
    i want to replace the engine ecu opel corsa c x17 dtl 2002 can i replace with opel com china ?
    dritan's Avatar
    Apr 2013
    can you tell me how can i replace, step by step procedure with opel com china
    thank you.
    here there
    it's a litllte triky. be carefull you'll need to program also BCM, IPC, ECU and IMMO. First you need pincode from car and pincode from your new ECU. You connect to car enter pincode and rested ECU from car, IPC and IMMO. Then switch new ECU enter his pincode and reset ECU. Now you'll hae to pair all back with old pincode BCM,IPC IMMO and ECU. If you can't program old keys buy a new key chip and program it. It will work
  10. The Following User Says Thank You to catala20032004 For This Useful Post:
    khaledrwan22 (17th February, 2017)
  11. #10
    Nov 2012
    I have Vectra C 2007 and I want to replace the ECM. Considering I have both pin codes is it possible to do it with OP-COM and If yes is it the same procedure as catala said ? My problem actually now is that for God know what reason the BCM no longer accepts the pin code and I can't reset and program it. Any ideas ?
