I tried this and it didn't work, I have a blue screen before this it was screeching static, and now nothing. I doesn't seem to even respond to the remote you only hear the clicking sound when you try the reset button.
Is this for a hard reset ?
This comes very handy for me.
you know if you logon to router and look at client list before turning on box then refresh after you can see which ip is assigned and just browse to it
save trying to count leds
Can't belive you didn' found an utility called "FlashWizard"; is fast indeed, reliable, tested by me and used many times (after headackes due to using Dreamup); works by LAN; you can fast backup your image first and flash another in a couple of minutes. First set connection param (IP, user, passw); use fixed IP in your DM as I did.
Tested on my DM500-s (genuine).
FLASHWIZARD_6_3.zip
PM: Italian made. Unzip, open .exe file; don't need install.
Can't be anything faster in my opinion.
Hope it helps!
Hi, I am am newbe but I think null modem cable route is easier. If "FlashWizard" method is easier somebody should do a step by step guide please.
got to the flash page, put the nfi file in and pressed flash, nothing is happening, do i need to put a different cable in or just do it from the router?
Does it work with the clone??
I could enter the Enigma Web Interface.
How can I upload the file to unlock Sky Germany?
Where can I got this file?
Thank you.
Hi, just got into the forum since I got an old 500s somewhere which could be useful again! Thanx for the guide
hi I have a dm500s and I tried turning off power then holding the power on for 20sec but nothing happen, the lights didnt start flashing.. all that happens is the green light turns on..
so i tried again and this time i just held down the power button for a couple minutes and still didnt work i had no flashing lights, and its definitly connected to my router because I am able to access the pli enigma screen via browser,,
this is an old box I have and I dont have access to setup password on this box so I am trying to flash it and start over..
really need help flashing this box pls..
edit***********
ok i know what a null modem cable is, just need to find a store that will sell them i guess..
