Results 1 to 4 of 4
    Aug 2011
    Default C3 1.4 petrol. Remote central locking times out
    Hi I removed the oem cd player as it was causing a 300ma drain. Fitted a standard cd player (kenwood) the car locks and un locks but after about 10 mins the remote locking Dosnt work until you wake bsi up by unlocking manually with the key in the door. Is there any configuration that needs changing in the bsi? I have planet.
    Jonny
    DK Veteran m3vuv's Avatar
    woodhall-spa lincs
    try checking for fault codes in the dash radio display then remove the radio in the bsi options using lexia,had the same issues some time ago,cheers m3vuv
    Meat-Head's Avatar
    what problem was you having?
    mastaflex's Avatar
    Jan 2009
    FR47310
    remove radio from BSI
