Results 1 to 8 of 8
    Nov 2008
    Default epg on my vu uno
    hi guys anyone know how to sort the epg on a uno, im using the vix image, i managed to get it working the first time, then after a few weeks it stopped working, i was using rytec for 28.2. i have repeated the the process but it doesnt work, any ideas guys?
    cheers
    V.I.P. Member dell_xps's Avatar
    Have you set it up to download every day ?
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Are you saving the epg to a hdd or the receivers ram?
    Double check that and make sure the file path is corrrect.
    working fine here for me on latest BH image.
    Freck
    Nov 2008
    i am saving to the receivers ram i believe, i have a hdd installed would that be a better option to save it to? also where are the setting for the epg, i can only find them under cross epg... is that correct
    Jun 2011
    yep save it to the hdd mate ALWAYS
    Sep 2010
    i save mine to a usb stick mounted in the rear of the receiver along with the picons and daily image backups.
    Sep 2008
    that would mean you dont record programmes rd
    Sep 2010
    Quote Originally Posted by cactikid View Post
    actually i do to the internally mounted HDD or the externally mounted NAS HDD. i simply use the usb stick for picons / epg data and daily image backups.
