Hi guys i really need help. I have checked the other posts on this matter and i am dreading the worst here. I have given my yellow wire the earth supply so did i give the temp sensor and the throttle even though their earths are good. I suspect a faulty ecu but i need to have the proof to make the customer buy a 2nd hand one alternatively i will attempt to repair the ecu if it is possible or if guided correctly. Also what is weird is the fact that when you get this car running you are able to remove the key whilst its idling then it will idle on. Another thing i noticed is that with the opcom plugged in and i check my actual values the battery voltage lays at 5.1V even though the battery voltage is 12 and when it starts the battery voltage in the actual values jump from 5 to 16 to 19 to 22v , the true signs of a bad earth but where i cannot see it. Lastly here is the fault codes attached P0100
P0352
P0351
P0353
P0354
P1540
Thats the recurring faults guys any info and help is appreciated
Thanks in advance
