It's unfortunate the PVR800 Editor doesn't give you the option to simply drag and drop channels like SeteditHD100.
alieditor is up to v2.3.0b but I seen no gain over the older versions.
hi guys just a quickie, can setedit be used with class HD 9000x usb STB?
many thanks
Here is one you need.
Channl Editor tool for Class HD900_Aman_gee.rar
so i could transfer my duo listing to an S11 ?
sounds good as ordered an S11 the other day
Hi!
Will this prog. work with Openbox S12 to?
I dont get this method. Is this mean we have to create .abs (image files) just to update our channel lists and then re-flash our box each time? Is there no simpler solution to create a .dbs file instead which we can simply just update our channel list with instead of having to generate a new image file (.abs) each time.
I read this somewhere "It has been brought to out attention that flashing dump files on the openbox overloads/overwrites info and damages it!
As dump files have firmware and channel lists combined, please in future flash the firmware first then load a channel list as no one wants there box to be fried!"
given that most people will have a box with a firmware that has channel lists combined, using your method then might cause people to run the risk of frying the box as you are having to create an entire image file just to update the channel list. Am I right or wrong here?
will SeteditHD100. work with the skybox f3 thanks
thanks setedit work on my openbox
will this work on a openbox x3 cheers
Hi..Can u please tell me..how to rename one of the Favourites in the list ?? I have AJ's channel list and its great...Just want to rename couple of Favourite groups like International to Asian and KIds to Children's Special etc..Is there anyway I can do that using the Box Remote ? I have Skybox F3....a small tutorial or guide will be helpful..Many thanks in advance.
Easy and working way as long as you have a dumped firmware with recently scanned satellites, otherwise when you import favourites, it will tell you there are channels missing.
I recomend you scan the satellites you want have your favourites set, then dump the abs firmware as you can only import the favourites to it and if they are not on the dump, they will not stick.
