Results 1 to 5 of 5
    Jun 2009
    Default hilux not starts no solution
    i have one hilux that not started normal.the car het into the sea .
    the ecu and the interior cobles has been change
    i have copy all the imobiliser system and the ecu has been sychro with the immo system.
    the strange is that the car starts when i give 12v at the start signal in the ecu .
    when i turn the switch ti start position the car goes to start but it stops and i get failure code p200 that says that there is injector open .
    the ecu has separate module for injector.
    all the positive and the negative goes ok in the ecu .
    if i start the car with 12v in the start signal in ecu a7 after a while i have fault in crankshaft sensor.
    what is the problem that ecu not started ?and started when i give separate 12v in the signal of start in ecu
    here is the wiring of hilux you can look in page 215+ to see the whole circuit
    Jun 2009
    ANY IDEA to do something
    KACZANUK's Avatar
    Aug 2009
    Brasil
    Quote Originally Posted by gadroulll View Post
    Hello friend
    I've got a 2005 hilux with the same problem that you reported
    How did you solve?
    Ashraf6119's Avatar
    Nov 2009
    UK
    Have you checked if NO any injectors are shorting to Ground and causing to shut down the system............Just to prevent the ECU for any more damage..............
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    KACZANUK's Avatar
    Aug 2009
    Brasil
    Quote Originally Posted by Ashraf6119 View Post
    Yes, guns and whip themselves are not short-circuit the mass.
    ECU has already been exchanged, Module EDU also has already been exchanged and the problem continues
    Already been done immo off and even then, only works vehicle with 12v feeding the ecu pin A7.
