Results 1 to 15 of 23
    gepakg's Avatar
    Serbia
    Default a4 2.0tdi 170hp DPF remove on PPD1.3
    Hi!
    Can somebody remove DPF and calculate chksums on audi A4 2.0tdi 170hp
    ECU siemens PPD 1.3 / 03G906018AQ
    regards Gepa
    test file and raport
    pass pw
    2 files
    test 1
    test 2
    regeneration off
    cks calculating in flasher (mpps v5)
    gepakg's Avatar
    Serbia
    i read it with BDM,possible to calculate chksum?
    regards Gepa
    Quote Originally Posted by macxlulu View Post
    pass pw
    2 files
    test 1
    test 2
    regeneration off
    florinyes's Avatar
    London Middlesex
    Load the file for us I do cks for ya..
    Whatever seems impossible is just not yet important enough.
    gepakg's Avatar
    Serbia
    thanx,you add chksum-ed archive!
    will post results tommorow
    regards Gepa
    pass pw
    2 files
    test 1
    test 2
    regeneration off
    ALGERIA
    IF DON'T WORK TRY MINE
    PW........PM
    gepakg's Avatar
    Serbia
    hi!
    report:
    file test1---car work but loose power till 3000rpm after that work correct...
    test2,and file from grinovsky work same in all RPMs car loose power,also maked 2 files by myself and same as test2 :-(
    anybody have idea?
    regards Gepa
    pass pw
    2 files
    test 1
    test 2
    regeneration off
    ALGERIA
    is there dtc in ecu? is there lampe on in dash?
    gepakg's Avatar
    Serbia
    no DTCs in ecu,no lame on dash...
    regards Gepa
    Quote Originally Posted by grinovsky View Post
    ALGERIA
    ok mate
    try this and repport
    as always,pw......pm
    gepakg's Avatar
    Serbia
    thank you friend,will try tommorow and post results
    regards Gepa
    ok mate
    I have the same car and would also need DPF off. There is also problem with the EGT sensor after the DPF.
    The Fault is:
    005213 - Exhaust Gas Temperature Sensor 3: Short to Plus
    P145D - 006 - Short to Plus - MIL ON
    Sensor is really broken but I think its only used for DPF strategies so if its possible to disable so there wont be obdII code it would be great.
    Here is the ori read by MPPS.
    Thanks in advance.
  13. #13
    ALGERIA
    change the sensor by a new and erease dtc to resolve this probleme,this sensor is not used only for DPF it's used for injection correction too
    then if you find probleme to dpf off you will find the help
  14. #14
    Got the new sensor installed. Now it shows temp ok. Now only need DPF off. Thanks
  15. #15
    ALGERIA
    Quote Originally Posted by gepakg View Post
    regards Gepa
    what's new doc?
