Page 4 of 4 FirstFirst 1234
Results 46 to 51 of 51
  1. #46
    Sep 2012
    Thumbs up Nintendo dsi 1.4.4e firmware
    if this helps anyone then great.
    i had the same problem, updated without thinking the crafty sods would put a block in, and went through all the checks that everyone else seems to be doing.
    anyway i went to the market and saw my indian friend and bought an R4i 3DS (R4i-SDHC) . it's in a reddish box and says wifi in the left hand top corner.
    Go to that website and download the new kernel (www.R4I-SDHC.com) unzip it and copy to the micro sd card but don't forget to copy the ds.dat as well.
    Then you will be up and running .
    contact me if you need any help.
    good luck
    Last edited by deeteekay51; 16th October, 2012 at 06:07 PM. Reason: error in web address twice
  2. #47
    Oct 2012
    Default firmware
    Nope, updating the kernel software didn't work.
    I need a new firmware, not software.
    Updating the firmware is by using a file like fw144.nds.
    copy it to the card and update it with an older NDS just using the update function in the kernel software.
    I'm just looking for the right *.nds file.....
  3. #48
    Dec 2012
    I wonder if someone could help me out. Am I stuck because I have a DSI at 1.4.3u??? I bought a d4i revolution card and have tried different firmwares and always get the "an error has occurred please hold down power button....."
    I also bought a D4I 3ds card but it turned out to be a fake card. It would try to load the card and give me the "this card is fake return to retailer" message.
    Is it because my DSI is 1.4.3u that I cannot get either of these cards to work? Do I have to update the D4I in a ds lite which I don't have??
    Any help would be appreciated!
  4. #49
    Jan 2013
    I'm having the same problem with my dsi...keep getting the "an error has occurred. Press and hold...." any suggestions. thanks!!!
  5. #50
    Feb 2013
    Hi All,
    Think I've got this sussed.
    I have two 1.4.1 cards, and someone updated the DSi to 1.4.4
    I have had to follow a staged upgrade path to get it to work:
    I used kernel version 1.42 from here:
    http://filetrip.net/f25763-R4i-SDHC-V1-4-2-kernel-(English)-1-42b.html
    to update to 1.43
    Then, I used Kernel version 1.56b from: http://down.r4town.com/R4i_V1.56b.zip
    to update to 1.4.4
    NOTE: you will probably have to change the date to get these kernels to work (I just set it back by one year)
    I hope that this helps!
    M.
  6. #51
    Mar 2013
    Yeah, this helped me so much. Thanks.
