sorted transponder settings have changed heres the settings if your having trouble
frequency 12109
symbol rate 27500
polarization horizontal
fec auto
then press ok to scan job done, hope it helps
frequency 12109
symbol rate 27500
fec auto
sorted thanks, just alter fec to 5/6 in dreambox edit,
hi all,for peeps just wanting 28.2 just use autobouquets plugin as posted here (post #464) as u will have a up to date list all the time, at the press of a button u can update anytime u need,p.s just to say thanks to catseye for the hard work he puts in with his bouquets,cheers shaun
For sports 1.2.3.5.f1 change fec 2/3 to 5/6
For sports 4 needs few more changes on dreambox edit:uploadfromtaptalk1429436955078.jpg
I keep getting tune failed on sky sports, even after new channel list sent by dbe,
any ideas?
wezley1986 (19th April, 2015)
Hi Rubiks
Thanks for the pointers
Is there anything else that needs done apart from chagning FEC? I changed it and I am still getting tuned failed.
Hi . check on the picture carefully all the details (sports4 you mean?) and compare them on dreambox edit with yours. You have to make them changes same as them on photo. I will make a 28.2 channel list tomorrow and put it on here if you not been able to sorted out but can not do that tonight as i am away from home.
Hi Rubiks
Cheers
All my sports are out except for news. I checked with your pic and all seems to be identical.
Cheers
