Results 1 to 10 of 10
    Jun 2011
    Default DDEC V Turbo Adjustment
    Hello
    I want to know how to adjust ddec v turbo. I dont have that special ecm for adjustment. All i have is dddl and i know that its possible to adjust turbo by dddl. Thanks.
    Top Poster torqueman's Avatar
    Canada
    Quote Originally Posted by a13xxc View Post
    Hello
    wt do you exactly want to adjust in a turbo?actuator length or somthing else?
    DK Veteran ddmech's Avatar
    Feb 2011
    middle of nowhere usa
    Go to dddl diagnostics window.At the bottom of the list it will say turbocharger actuator adjuster routine.
    Top Poster peter21's Avatar
    San Miguel, SV
    Default turbo ddec-v
    hi, well here is the procediment to adjust the turbo actuator, i think you need DRS to reprograming the ecm to make adjustment.......
    2009-08-28_turbo ddec5 adjustment.pdf
  5. The Following 2 Users Say Thank You to peter21 For This Useful Post:
    Elfer (22nd November, 2013), RICARDO ORTIZ (7th September, 2013)
    Jun 2011
    thank you guys for responds...i dont have test ecm and dont want to re-flash original one. there is easy way to adjust turbo. i have been told this instruction.
    1. warm up engine to 185-190 f
    2. connect dddl and go to diagnostic window.
    3. accelerate engine rpm to 1000 and hold it
    4.egr valve must be closed 11 %, VGT Vanes Actuator 67 %, Boost Pressure 19-20 kPa. Dont pay attention on turbo speed.
    5.if Boost Pressure is less or more then 19-20kpa, turn actuator's rod to get proper boost pressure.
    Some body know about this ? want to make sure i am doing right.
    Jun 2011
    I did adjustment this way (see above) yesterday..it works...drove loaded truck uphills and in the city. It runs perfect.
    People this is the easy way to adjust turbo...
    Feb 2011
    I adjusted differnt ways but this seems simple enough.Will try it friend.
    Quote Originally Posted by ddmech View Post
    How you do it ddmech?
  10. #9
    Member riggerout's Avatar
    Sep 2010
    Yes, many ways to adjust VGT actuator,
    what the exact ?
  11. The Following 3 Users Say Thank You to riggerout For This Useful Post:
    Elfer (22nd November, 2013), juan79 (23rd November, 2014), RICARDO ORTIZ (7th September, 2013)
  12. #10
    Feb 2011
    We used a regulator to set the actuator.I think the procedure is in dd service manual.
